Hello! and thanks for looking. I just purchased a 95 Corvette, ran great, no problems, though the coolant looked brownish nasty... so i did a little research and decided to flush the system my self, i took off the knock sensors, ran low pressure water through for 20 minutes or so, cleaned out all the lines and overflow tank, pieced it all back together, i put coolant in the waterpump/block through the thermostat housing to try to eliminate as much air as i could. and now it over heats, digital says 220-225 before ill turn it off, and analog gauge says 245ish. i replaced the sensor for the analog gauge as well...says the same thing, i looked over my lines again and again... i only found one burp valve.. (Bleed screw) on top of the thermostat housing...and it still over heats?!
by the way: before i flushed the system it ran at 185-192 range never higher.
Wrap a rag around the bleeder screw (there is only one on a 95) and bleed the air out when it is hot enough that the t/stat is open. Just be sure you don't have coolant running down on the opti.
From: Portsmouth Virginia 396LT4 435RWHP/400RWTQ Best so far 11.26 @ 123mph
If I had to guess,I would say 1) You probably still have air in the system which normally requires a few heat cycles to remove it all or 2)you have installed the thermostat backwards if the temp is actually that high. The vent screw on the housing is the only place designed to burp the system. The remaining air will eventually work its way to the bleed screw at the top. You normally wont get it all out the 1st time.Just bleed it a couple of more times after driving it.
Rick
For some reason people got mad when I have said this in the past (you can be sure someone will squeal in outrage this time, too) but I have had better luck "burping" the system at the surge tank. If you race the engine a little while looking into the surge tank filler hole you may see some bubbles coming out. I did, and that solved my problem even after bleeding several times at the "proper" location where all I got was coolant.
But, as others have said, it could also be the thermostat.
