Where does the "unseen" end of the wire that runs from the oil pressure
sensor/gauge (mounted between firewall & engine) lead. I'm getting
faulty readings from oil pressure gauge needle and I'm checking the
connections at both ends. I'm trying avoid returning to the place that
created this problem when they replaced the steering rack & pinion last
week. Thankyou.
