Convertible top replacement info needed
Does any one have info on or experience with California Convertible Tops?
How about weather-strips from Wilcox? They have a great “Forum Discount” price.
Mike
Just poke around, you'll find it. Step by step with lots of pictures.
You'll need new weatherstrip (7 piece kit) and a can of 'vinyl cement.'
Take your time. Read the directions several times before you get started. There are a few times when it helps to have a helper for a few minutes (mostly when you put the new top on for the first time and want to make sure it's centered properly).
You just need common hand tools including some small socket wrenches.
There are a lot of screws, so I took a shoe box and turned it upside down and poked holes in the bottom as I took each row of screws out. then I pushed them in the holes in the shoe box in order. When it came to reinstallation, they were all in the right place and I didn't lose any.
The plastic plugs in the weatherstrip are a different story. They cannot be removed without flying great distances, so be careful to try to capture them before they fly off. The article warned about this, and I thought I took sufficient precautions, (you have to pry them off) but, oh well. They aren't showstoppers, and one day I'll replace them. As you might imagine they are unique and no one sells them.
All in all, it was a satisfying experience, and you can point to it and say "I did it myself!"
Good Luck!
Here's the link to the place where I got my CD.
http://www.topgunwon.com/dvd/
I've not replaced my top yet but have watched the video! Great quality and I think well worth the money.
I'm waint for my tax return before I do mine but plan on posting my coments after I'm done.
Mike
