Installing door panel carpeting
Old Apr 11, 2002 | 10:42 AM
robertpel9's Avatar
robertpel9
Default Installing door panel carpeting
I am having a real hard time with this seemingly simple procedure. Whats the easiest way to do this. It seems that the lower part of the upper door panel shold be in contact with the black panel i need to attach the carpet to but it is curled up. Do i need to super glue it down or something. AAlso this vinyl wrap on the bottom of the capet that wraps around the bottom of the black panel is a real bit@h. Any tips for this install. I thought it wold take 10 minutes but its a real pain in the behind. Any help would be appreciated.
Thanks,
Bob
Old Apr 11, 2002 | 12:21 PM
robertpel9's Avatar
robertpel9
Default Re: Installing door panel carpeting (robertpel9)
ttt
Old Apr 11, 2002 | 01:14 PM
stillthere's Avatar
stillthere
use 3m yellow or black weather stripping adheasive. remove the old carpet and all the old glue. you will need to staple the vinyl part on the back of the pannel. i put bricks on mine to hold the carpet flat until it dried. its a days work.
Old Apr 12, 2002 | 11:25 AM
robertpel9's Avatar
robertpel9
ttt, please help!! I don't want to remove the whole door panel just to replace this little section of carpet.
Old Apr 12, 2002 | 12:12 PM
stillthere's Avatar
stillthere
read my step by step on how to do this on the other post" door panel carpeting from eckler." this is a big job. it will take you all day to do it right.
To Installing door panel carpeting
