I replaced my front Y pipe with one with out precats :)
Old 02-05-2011, 02:58 PM
torchred89
torchred89's Avatar
Originally Posted by 8valve
WHen you replace the front Y pipe with one without Pre Cats, and also remove the Main Cat, will you have any problems with the Oxygen sensor operating correctly ? I am also considering running duals all the way back. Somewhere I think I read on the forum that removing the cats woudl cause Oxygen sensor problems. I have a 87 with only one Oxygen Sensor on the left pipe.
8Valve
I had to put preheated one on mine.
Old 02-05-2011, 05:16 PM
Geardo
Geardo's Avatar
Originally Posted by pmihaltian
You can get a cat-less front Y-pipe at most of the Corvette Parts houses. Here is one with a high output main cat:
http://www.ecklers.com/corvette-y-pi...1986-1991.html
I just ordered that today, and Ecklers has a 15% off coupon code on their site.
Old 02-06-2011, 12:20 PM
8valve
Support Corvetteforum!
8valve's Avatar
May I ask the part number on the heated 02 sensor you used. Where did you get the power to run the heater. Thanks for any info you can share.
8Valve
Old 02-08-2011, 08:22 AM
TIMSTERS VETTE
TIMSTERS VETTE's Avatar
Thanks for the link, definately the route I am going.
Quick Reply: I replaced my front Y pipe with one with out precats :)
