Can anyone suggest the proper method for removing the front license plate cover on a 1995 corvette?? I looked in the owners manual for a picture or diagram showing the removal procedure.....I don't want to bend and break the body cover to install my front plate.
Not that you asked. 87, two tabs at the top, two screws at the bottom. Mine are Phillips head screws but I might have lost the original and replaced them in the last 20 years.
I have a '95 and mine is original. It has two torx screws on the bottom and two tabs on the top. The screws on the bottom align with two of the letters on the cover, I forget which ones, but you can see them with a flashlight shining in the space between the cover and the body.
This is a timely question/answer as I have to install my front plate. In California they've raised the cost of all citations and i can't afford the ticket.
