water drain 94 C4
Old Feb 11, 2011 | 06:31 PM
C&M Racing's Avatar
C&M Racing
Default water drain 94 C4
I have found the underhood water drain on the drivers side of the cowl but I have not found the passenger side. Based on how much crap was in the drivers side I would like to clean out the passenger side.
Old Feb 11, 2011 | 08:08 PM
VetteMed's Avatar
VetteMed
If memory serves me correctly, it's inboard of the heater box area, sort of behind the area where the hood weatherstrip diverts rearward for a few inches (for the distributor in the L98 cars).
Old Feb 12, 2011 | 09:45 AM
Analog Kid's Avatar
Analog Kid
There are two on the drivers side. One by the battery and the other by the wiper motor.
The one on the passenger side is more the a/c evap drain. If you remove the body side panel you'll be able to see it much better. And yes, it gets clogged too.
Old Feb 12, 2011 | 09:49 AM
C&M Racing's Avatar
C&M Racing
Looks like I need to look closer. Thanks for the help and if I find them I will take some pictures.
Old Feb 12, 2011 | 02:18 PM
jeffp1167's Avatar
jeffp1167
I know there is another drain at least on my 90, it comes from the dash somewhere and goes into the hole where the power door wiring passes through the "a" pillar. I'm not sure where this drain originates though.
To water drain 94 C4
