I'm redueing my interior and I came accross a problem while removing the seat belts. The torx bolts, a couple of them are stripped out. I can't seem to get a good grip with a pair of vice grips and was looking for suggestions.
Try a large EZ-Out. If that doesn't work,...
1. Put an open end wrench (slightly smaller than the bolt) over the bolt, draw the dimensions with a silver sharpie, and then use a dremel with a grinding tip to grind edges on the bolt to fit the wrench. Turn it out with a wrench.
2. Weld a nut on top of it (cover interior with a welding blanket), crank it out with a wrench.
