4+3 Clarification
Old Feb 13, 2011 | 09:41 PM
Bonecrusher3480's Avatar
Bonecrusher3480
Default 4+3 Clarification
Since I am a noob with my kickin 86, can someone smarter than me explain the 4+3 and exactly how to drive it??? Hope this is not too remedial to post but I want to be sure im treating her right. Thanks
Old Feb 13, 2011 | 09:59 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
Did you read your owners manual. If you do not have one I suggest you buy one
Old Feb 13, 2011 | 10:02 PM
Bonecrusher3480
If I had an owners manual I would not have posted this question. Can someone else please give me some info?
Old Feb 13, 2011 | 10:49 PM
rodj's Avatar
rodj
Is a 4spd trans with a 2spd behind it giving 7 gears
Once engine is up to specified temp O/d will be automatically engaged ( Govt fuel saving measure ).
so when you shift , you have 1st , 2ndOD , 3rdOD , 4thOD .
O/d will also automatically disengage on hard Accel ; just like a auto kicking down
Most over ride this function by turning the O/d off using the O/d button before driving off so as to have normal 4 spd trans and only engage the O/d on the highway
Pushing the button gives complete manual operation of the O/d as required
Depressing the clutch while engage / disengage O/d helps it live longer.
If you do not know history of your O/d; change the fluid and filter NOW.
Most mechanical O/d Problems are associated with O/d that were not serviced at factory specified 12,000
miles
Due to age ,there are many minor electrical problems ( bad wiring / old relays / etc ) that are easily and cheaply fixed
Old Feb 13, 2011 | 11:09 PM
Bonecrusher3480
Thanks a ton. I will get on the filter/fluid asap! Did this 4+3 come on automatics as well??
Old Feb 13, 2011 | 11:28 PM
rodj's Avatar
rodj
Houston ,I think we have a problem
4+3 is a manual
Auto is a auto
Period
O/d filter no longer available but can use these part #
http://forums.corvetteforum.com/1571645223-post6.html
To 4+3 Clarification
