Things I learned today....
Old Feb 19, 2011 | 12:19 PM
Soloflexerus's Avatar
Soloflexerus
Default Things I learned today....
Is there a forum where people can share knowledge about something they learned while working on their car?
You know, things like using a paint brush dipped in chassis grease to lube complicated or hard to reach parts, like a door hinge.
Another example: Here's something I figured out about inflating my tires to the right pressure:
We all know that the right way to check tire pressure is when the tire is cold, or, at worst, when the car has been driven less than a mile before taking a measurement
My problem was that the nearest gas station with an air pump is about 3 miles away from home. Believing that doing things the right way is the best way (usually), I wanted to check the tire pressure on cold tires.
My solution was to stop by the gas station on the way home, over inflate the tires a little, then bleed off the excess pressure the next morning when the tires had been sitting for 10-12 hours.
Now, if I can find a decent tire gauge I'll be good to go.
Old Feb 19, 2011 | 12:31 PM
Sweet 90's Avatar
Sweet 90
Maybe, I think you're close though
Old Feb 19, 2011 | 12:51 PM
Frizlefrak's Avatar
Frizlefrak
Yes. Right here.
Buy a compressor. Harbor Freight has a decent 2 hp for under $100 right now. Will fit the bill just fine.
Happy Motoring.
Old Feb 19, 2011 | 01:17 PM
Jon Hekking's Avatar
Jon Hekking
Sweetsie, why do you torment me so
Weighing the risk verses benefit...................
Old Feb 19, 2011 | 01:28 PM
Frizlefrak's Avatar
Frizlefrak
Birds of a feather.....
Old Feb 19, 2011 | 01:45 PM
Sweet 90's Avatar
Sweet 90
Don't Duck with me boys
Old Feb 19, 2011 | 01:59 PM
socalman's Avatar
socalman
St. Jude Donor '10
unduckingbelievable!
Old Feb 19, 2011 | 02:53 PM
Bronze85's Avatar
Bronze85
Old Feb 19, 2011 | 02:55 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
You could also buy an air pump that plugs into your accessory plug. It's always a good idea to pack one around with you anyway.
But I would recommened a small air pump like FF stated as well.
But to answer your question, socalman has a DIY sticky with lots of good stuff that can be added to.
RetiredSFC 97
Originally Posted by Bronze85
Or that
Old Feb 19, 2011 | 06:16 PM
Soloflexerus
'84 Vette
Problem Area:
Fuse panel door.
Problem description:
On the fuse panel door there is a “key” that closes the door with ½ turn. On my car, for some reason, the “lock” was rotated 90 degrees, which means the key wouldn't work, it wouldn't hold the door closed.
It's easy enough to use needle nosed pliers to pinch the lock and remove it. Problem is, the lock will fall behind the fuse panel, among all those wires and sharp things. Then you'll have a hell of a problem laying on your back, with one of you kids holding your bad leg in the air, trying to feel around for the lock.
Before I pinched out the lock, I put a piece of electrical wire through the hole in the center lock. On the end I was holding, I bent the wire into a big “L” in case I dropped it. Then I found the other end of my wire under the dash and put a hook on that end.
When I pinched out the lock it went dingle, dingle, dingle down the wire, then stopped at the bottom hook, thus eliminating the chore of trying to find by feel where it landed had I not used the wire. Just work your wire gently, don't go poking things too much to get the wire out the bottom of the dash.
Putting the “lock' back in wasn't too bad, two tries and I heard a heart warming snap.
Old Feb 19, 2011 | 06:36 PM
Soloflexerus
RetiredSFC97,
Thanks for the tip. I tried to find socalman's DIY thread but gave up. You know how lazy we newbies are.
Sure, I could buy a pump, but then I would have to spend money. Free solutions are the best. Besides, when I'm working for myself my labor is cheap.
Old Feb 19, 2011 | 06:40 PM
RetiredSFC 97
RetiredSFC97,
Here's the sticky. It is located at the very top of this section. Just send your ideas to him and he can post them in the sticky for us.
http://forums.corvetteforum.com/c4-g...ps-w-pics.html
I understand the free solutions. I prefer them if possible.
Old Feb 19, 2011 | 07:40 PM
Churchkey's Avatar
Churchkey
Here's a "decent" tire gauge.
https://www.lefthanderchassis.com/v2...dgroup=2512005
To Things I learned today....
