its not low enough!!!
Old Mar 1, 2011 | 01:00 AM
96 collectors's Avatar
96 collectors
Default its not low enough!!!
i just installed rear lowering bolts on my 96 ce and all they did was match the front stock ride height. i want the rear lower to were u can get just one finger in between the tire and fender before i even lower the front. is there any way or better lowering kit for it. i got my kit from mid america motorworks. can any one help?
Old Mar 1, 2011 | 04:48 AM
bizaro's Avatar
bizaro
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14
This should do it...
Old Mar 1, 2011 | 07:27 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
The longer the bolt used, the lower the car will be.
You don't really need a "kit" for the rear.
After you installed the longer bolts, did you drive it around for a day or so before measuring?
Any time you lift the wheels off the ground on a C4, the suspension will look "raised" until you have a chance to drive it.
If it's still not low enough for you, just buy longer bolts.
Take one of your current ones to a hardware store and get a matching (longer) one.
Old Mar 1, 2011 | 08:14 AM
Z51JEFF's Avatar
Z51JEFF
Get a bigger hammer.
Old Mar 1, 2011 | 10:09 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Here is what Frizzie uses:
And Sweetsie uses:
But seriously, go with the hardware store bolts but make sure they are the same "strength" bolts that the aftermarket companies use. There is a lot of pressure on those rear springs.
Old Mar 1, 2011 | 11:15 AM
Flame Red's Avatar
Flame Red
Gosh, I feel for you brother. I would be in the very same boat if my engine was gone. I'm a decent wrencher, but I know my limitations and I don't have the place to do the work, the equipment necessary and I just too old.
If it were me, I would walk or not depending if you could truly find a mechanic that would not charge you for the dreaded Corvette Tax. Those are almost impossible to find around me though. Best thing you can do is shop around and get several estimates and see where you stand. Try to make it a pure economic decision and not an emotional one. Otherwise, you may find yourself putting more into the car than it is worth.
If it were me, and I was putting in $7K, I would be looking for a C6 instead. For $3K, I might be willing to keep her. Sad to say that these are just 26 year old cars in the market place.
Old Mar 1, 2011 | 01:17 PM
wro87's Avatar
wro87
You will need to go to some GOOD Quality bolt place (I used FASTENAL). When I ordered in the first too I had dropped it so low that you could not get your finger between the wheel and the bottom of the wheel arch! Dragged way too much and since our is a vert had a hell of a time getting in/out of the drive with the x-brace. Went with one a little shorter and all is well still sits low and it is 1" lower than the kid's 92'ZR1 that is lowered nice.
Good Luck wro87
Old Mar 1, 2011 | 01:31 PM
96 collectors
yea i drove around for about an hour or to so the springs would settle but its still not low enought and i was thinking that if i would go to an fastnal shop and get a longer bolt but i was just wondering if there was any other ways and thank you for the info
Old Mar 1, 2011 | 01:32 PM
96 collectors
thanks every one for the info my next day off im getting some longer bolts will take before and after pics to show u guys Thanks
Old Mar 1, 2011 | 01:35 PM
usmc_butler's Avatar
usmc_butler
I dont know how this relates to lowering the rear of the OP's Corvette, wrong thread maybe?
Old Mar 1, 2011 | 02:20 PM
turbotim23's Avatar
turbotim23
What I did in back is buy grade 8 threaded rod and cut it to 12", then welded a frame nut on the top and used nyloc nuts on bottom. Now I can adjust up and down anywhere I want. Good Luck Tim
Old Mar 1, 2011 | 04:54 PM
Sweet 90's Avatar
Sweet 90
I'm thinking Time Warp
Old Mar 1, 2011 | 05:40 PM
Casket86's Avatar
Casket86
DAYUMM! What is the tensil strength of that denim?
Old Mar 2, 2011 | 12:06 AM
corvettedan22's Avatar
corvettedan22
My lowering experience.
http://forums.corvetteforum.com/c4-g...-i-did-it.html
Old Mar 2, 2011 | 12:38 AM
96 collectors
Originally Posted by corvettedan22
thats how mine looks and i dont like it its not low enough you car looks great and its has a nice stance and ever thing but i want to go lower
Old Mar 2, 2011 | 01:06 AM
yaknow's Avatar
yaknow
after 2 year corvettedan22 still has the whole ride height figured out better than anybody on this forum
Old Mar 2, 2011 | 01:15 AM
corvettedan22
so take out all the rubber ! Slam it and you will be good to go ! I must say it will look good !
To its not low enough!!!
Old Mar 2, 2011 | 07:53 AM
Z51JEFF's Avatar
Z51JEFF
Are you sure about that?[IMG][/IMG]
Old Mar 2, 2011 | 10:19 AM
Desert LT1 Vette's Avatar
Desert LT1 Vette
she looks very unhappy and i bet she or it would throw the car's center of gravity to hell.i bet if i give her a brownie shell smile
Old Mar 2, 2011 | 10:34 AM
kimmer's Avatar
kimmer
C4 of the Year Finalist
There are shims in the center of the spring when moved will lower it more.
