power window failure
Old Mar 1, 2011 | 03:26 AM
#1weatherman's Avatar
#1weatherman
Default power window failure
I have only had my '92 vette for two weeks and already the passenger window no longer goes up and down. When either of the window switches are pushed back and forth, there is no sound at all. Is this a common issue and what is normally the culprit, the motor, regulator, or switch? Thanks.
Old Mar 1, 2011 | 10:14 AM
Goldcylon's Avatar
Goldcylon
My money is on the passenger window motor assuming the Drivers window is working.
Old Mar 1, 2011 | 10:39 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
While I tend to agree with GC, the passenger window switch goes through the drivers side switch. Unfortunately, that is a very expensive switch. Before removing the window motor, put voltage on it to make sure.
Old Mar 1, 2011 | 12:42 PM
jeffp1167's Avatar
jeffp1167
FSM says if neither control make window work replace drivers switch if motor is known to be good. But you have to unplug motor to test the pigtail.
To power window failure
