catalytic converter
Old Mar 7, 2011 | 12:00 PM
j/t's Avatar
j/t
Default catalytic converter
my 1985 is bone stock........is there really any advantage in deleteing the catalytic converter ? will the check engine light come on if I do ?
Old Mar 7, 2011 | 12:16 PM
fisher auto's Avatar
fisher auto
You might get a little more sound, You'll smell it for sure and the check engine light will come and go!
Old Mar 7, 2011 | 01:14 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
There will be no codes, the 85 does not monitor after the cat. There will be more noise (about 40%). There will be no change in fuel economy or performance unless the old one is plugged. There should be no large increase in smell. There is really no advantage to doing it, and it will affect resale if you live in or near to a monitored area.
Old Mar 7, 2011 | 01:25 PM
c4cruiser's Avatar
c4cruiser
Your 85 has a pair of "pre-cats" in each side of the front Y-pipe. There is also a "main cat" where the front Y-pipe connects to the single exhaust pipe leading to the rear Y-pipe.
You don't mention where you live or if you have to have an emissions test for plate renewals so that may be a factor in your decision.
As mentioned, you may not see a lot of increase in power if you simply remove the three cats. There are replacement front Y-pipes available without the pre-cats and it's not hard to fab up a pipe to replace the main cat. There won't be a code set so no SES light will come on.
But most muffler shops will refuse to remove any working cat from a car. The federal gubbmint can levy a huge fine (5 figures ) if a shop is caught doing that without replacing a defective unit.
You would be better off with true duals and a pair of free-flowing mufflers to pick up a few HP. The various catalogs have true dual exhaust pipes that bolt in and accept the stock mufflers or aftermarket ones made for C4's.
Old Mar 7, 2011 | 01:47 PM
jeffp1167's Avatar
jeffp1167
86 was first year of precats, don't think his 85 has them unless it has been changed.
Old Mar 7, 2011 | 01:59 PM
gkrynick22's Avatar
gkrynick22
I removed my cats in my 85. It definitely has a better sound to it then before. My check engine light does come on every once in a while, which I thought was because of the missing cat. Guess i'll have to check into it. Performance was there was no notable difference. No difference in smell either.
Old Mar 7, 2011 | 03:18 PM
ejscarfo's Avatar
ejscarfo
no pre-cats in the 84 or 85 front y-pipe.
You won't see any performance gains really. You will get a louder exhaust note and if you have an automatic you may notice that the low end torque that was there before has moved further up the power band so it will seem the car has lost some power.
As far as setting the CEL, I had gutted a cat on an 87 Firebird and it never once set the light in the 8 years I owned the car so I doubt your car would set it off. If you don't care or need to care about emissions, you can just gut what you have and re-install the empty shell. It will look like there's a cat there in case a visible inspection is needed for inspection, etc.
If your cat has gone south on the other hand and you still need to pass emissions, pick up a cheap direct fit from eBay or Rock Auto, should run you about $100. The cats on the 84 & 85 bolt in to the front and rear y-pipes with 4 bolts on each. If you still have the original on your car, I can guarantee that will have to put a torch or something to the front bolts to loosen them and get it off.
Depending on your local laws, if you remove the cat completely you may not be able to pass vehicle inspection even if your car is emission exempt so check that out.
Old Mar 7, 2011 | 03:23 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Hang on to any clean air parts because you never know.....
Old Mar 7, 2011 | 04:36 PM
j/t's Avatar
j/t
Default 1985 catalytic converter
thanks to all for your input. after reading all your responces Ive decided to leave it alone .......just drive it..........thanks J/T
To catalytic converter
