What to do... Cam?
Old Mar 10, 2011 | 03:15 PM
Vetster88's Avatar
Vetster88
Default What to do... Cam?
I posted up in the tech section and to surprisingly not get the input I thought I would
I need to refreshen my motor... figured I can get more out of the general section.
Im going with my "stocker" TPI might do some runner/intake port matching
Bore the block 30
retain my 113 heads
The cam is my toughy.
Id like a cam with thump but not kill driveablity
OR
A cam with High TQ output.
1700-5500 rpm power range is possible.
I do have a lunati voodoo 60101 cam n lifters.
I love the way the cc306 sounds but its probably to much cam for the tpi.
any cam suggestions and or audio/video??
Old Mar 10, 2011 | 03:41 PM
tehcarguy's Avatar
tehcarguy
Lingenfelter makes a cam thats good for the TPI intake.
Old Mar 10, 2011 | 10:14 PM
93Rubie's Avatar
93Rubie
If you are going to stick with your TPI setup. You need a cam in the idle to 5000RPM range. No big lumpy units. The TPI setup is for low and mid range torque. Focus on that. I think 1700-5500 is too much, without a bigmouth kit for the TPI.
Old Mar 10, 2011 | 10:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Use that 60101 thats plenty, youll like it.
To What to do... Cam?
