any suggestions welcome and appreciated
hey i am looking into buying a 1985 c4 with a tpi 350. it is a solid car and i have followed it for years, the only main drawback with this car is it is a flood car. before it was flooded it had a problem with fouling the spark plugs. about once a month it would have a billion codes. unhook the battery give it 10 minutes and it would fire up and run great. the plugs would be so black it wasnt funny, put a new set of plugs in it and it would always run like a champ. all i really know about its mechanical history is a few years ago they pulled the heads and had a 3 angle valve job done. not quite sure what all needs to be done but it hasnt ran for prolly 3 years. someone who had it before said after it broke down it just needed a fuel pressure regulator, but i dont know because i have never tested it myself.so any suggestions on what it could be or what i need to do to retain the fuel injected setup are welcome. thank you
There are a ton of good ones out there and more coming up as the weather gets better. My advice?
If you are getting it for free there is an outside chance you will come out even, that is a decent reliable car with a reasonable investment. Otherwise, what everyone else said. There is a reason why flood cars are totaled.
AS stated I guess it depends on how much you wanna tackle and how cheap you can get it. The guys are right, with the depressed market, if the guy is asking any money for the flood car you can spend it better elsewhere.
C4's (good ones) are abundant and cheap. A flood car is a parts car IMHO....anything else it will be a living, breathing, nightmare. What Ron said.....Run Forest, Run.
