Primary cooling fan
Old Mar 12, 2011 | 08:13 PM
liuhisn's Avatar
liuhisn
Default Primary cooling fan
Does anyone know at what temperature does the primary cooling fan turn on at idle? The auxiliary turns on at about 235 degrees. The fan motor is good and I have replaced the temp cooling switch on the engine block. The primary fan does not turn on. Is it supposed to turn on only when the car is moving?
Old Mar 12, 2011 | 08:20 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Not all years of the C4 are same.
So, list all the important information that will help others help you.
Old Mar 12, 2011 | 08:40 PM
liuhisn's Avatar
liuhisn
The cooling fan does not come on at 226 Degrees as the repair manual says. The car is an 1988 corvette. The auxiliary fan does turn on. My question is, Does the cooling fan only turn on while moving? I have replaced the thermostat. It just seems to be running a little hotter than normal. All of the relays have been changed. Is there a switch inside of the fan motor?
Old Mar 12, 2011 | 08:44 PM
slicked25's Avatar
slicked25
My 92 PCF turns on at 186 that's if the A/C is off of course.
Old Mar 12, 2011 | 08:49 PM
rodj's Avatar
rodj
Originally Posted by liuhisn
cooling fan does not come on at 226 Degrees All of the relays have been changed. Is there a switch inside of the fan motor?
Does the Pri fan itself actually work?
Have you got 12V power on the heavy red wire at the fan relay?
Will relay operate if grn/ wht wire at relay grounded ?
Computer turns on fan from temp readings it gets from CTS;
If CTS is sending bad temp readings then engine would be running rough so fair to assume problem is with fan / wiring itself
On a '88 the temp switch only operates the Aux fan in front of radiator ( if fitted ) and it is in the drv side head ;
not the block
Old Mar 12, 2011 | 11:21 PM
liuhisn's Avatar
liuhisn
Ok I will test the fan itself. Thanks
Old Mar 13, 2011 | 07:06 PM
guno89's Avatar
guno89
I have an 89. The fan should come on if you put car in aux mode and pull the codes. When my main fan didn't go on it was a relay. I took the relay from the aux fan and wala my main fan worked again.
Old Mar 13, 2011 | 08:39 PM
liuhisn's Avatar
liuhisn
Where is the primary fan relay? The secondary fan relay is on the radiator shroud. That relay works.
Old Mar 13, 2011 | 08:41 PM
liuhisn's Avatar
liuhisn
Put the car in aux mode? Do you mean just hooking the code reader up to it?
Old Mar 13, 2011 | 10:47 PM
guno89's Avatar
guno89
On drivers side behind the wheel its mounted. Kind of across from the battery. .
http://s599.photobucket.com/albums/t...nt%3Dwheel.jpg
****Mine has 2 relays, since I have a 6 speed****** If you have 2 of them its the 2nd relay, the one further from the battery.
As far as aux mode, when you pull the codes the fan should go on.
Old Mar 13, 2011 | 10:57 PM
guno89's Avatar
guno89
To Primary cooling fan
