Front spring
Old Mar 15, 2011 | 02:54 PM
FWC's Avatar
FWC
St. Jude Donor '13, '15-'16,'18 thru '25
Default Front spring
I posted a few weeks back about my front end being "too low" as it turns out my front spring is not only broke it's in Charlie Sheen territory. Anyway, it's new to me sorry no pics yet but I will soon. 96 coupe LT1 with 52K, I intend on driving it as much as possible and after reading as many posts as I could find I came up with this. Replace it with a new front spring and Bilsteins for the Z51 option. That combo seems to be acceptable, any nay sayers? No racing or autox btw.
Old Mar 16, 2011 | 03:51 PM
sailorsteve's Avatar
sailorsteve
Any reason not to replace with the same part #s?
Old Mar 16, 2011 | 04:30 PM
StealthLT4's Avatar
StealthLT4
That's exactly what I've been trying to do for about 6 months now; good luck finding a front '96 Z51 spring. The code is FSM, FSS, or FSR. 73 N/mm for 2 of them, 75 N/mm for the other (figured it was close enough). I finally settled for the base '96, which is code HA at 60 N/mm
But other than that, sounds like a great plan!
Old Mar 16, 2011 | 04:41 PM
sailorsteve
Try www.contemporarycorvette.com. They may have a used one.
Old Mar 16, 2011 | 08:51 PM
FWC's Avatar
FWC
My mistake, I am only doing the shocks in the Z51 option, staying with stock spring. Ordered it thru Corvette America today and said I will have it on Friday, surprised how quickly, installation next week!
Old Mar 17, 2011 | 12:22 AM
Eakster's Avatar
Eakster
If it's not too late, I would talk to Vette Brakes and Products They do a range of springs. I discovered my car had one of their 'sport' front springs which I like, however I think the front (stock) shocks are waaaay too soft. Would love to try a Z51 setup and see how it feels in comparison. Mine is lowered also and has minimal travel. Some members have spoken very highly of QA1 adjustable shocks, but you need a few more $ for those
Old Mar 20, 2011 | 04:46 PM
FWC's Avatar
FWC
While I was out for a run courtesy of Nike not Goodyear that is, I had time to think. Along with the new front spring and 4 new shocks I am also putting on 4 new tires. My question is this, when should I do the alignment immediately after the work or put a few hundred miles on to let the suspension settle?
Old Mar 20, 2011 | 04:49 PM
StealthLT4's Avatar
StealthLT4
Yes, you should let it settle, but not a couple hundred miles. I'd say a week, and it should be settled.
Old Mar 30, 2011 | 06:37 PM
FWC's Avatar
FWC
Got the spring in, wasn't a direct fit needed to add shims as the new one is thicker than the original. All new shocks and tires, rides much better considering the old spring was broken in half. Just in time for the incoming snow, wont get it out again until next week, damn!
To Front spring
