carpet
To add to this, today I pulled my new carpet out to replace the pad and sound deadener that I didnt do the first time.
My bad. You need to remove the console to get the 'across the tunell' padding out and then the new in and remove the seat belts. My old padding didnt smell moldy, but it was wet down under the foot area and its that oem padding that retains moisture. I'm installing 70mil 'fatmat' and will post pics, I have the befores but not the afters.Last edited by oldalaskaman; Mar 19, 2011 at 01:46 AM.
didnt mean to hyjack this thread, just p.o'd at myself for not doing it right the first time.
You just have to do small areas so the glue doesn't cool down. No way will interior temps exceed what the glue gun does so no chance the glue will get that hot for the carpet to release.
Gotta run!
I got my carpet kit in today, cant wait to get started replacing my old worn out stuff + the MAD Vet insulation kit I got......I was wondering if ERNNRON has any updates to his progress?
I think I will use the UGL contact cement previously mentioned, can anybody elaborate on what this is?
So Im waist-deep into the carpet R&R on my 91. Turns out the ACC mass-backed carpet also includes some jute-padding.
Heres my question: I have the MADVET heat/sound insulation kit I want to install too. So, whats the best approach: Place the heat insulation down first, and then the jute padding and with the carpet on the top layer? Putting the foil insulation over the jute doesnt seem like it would work very well. On the other hand, the jute padding seems to be tailored to fit into the area exactly....
