LT1 and LT4 differences
Old Mar 20, 2011 | 10:40 PM
robs87vette's Avatar
robs87vette
Default LT1 and LT4 differences
My neighbor bought a 96 that was sold to him as an LT4. As I looked at the engine it appers to me (with my limited knowlege) to be an LT1. I was convinced he had been misled in the deal. However I came across a thread here which showed a pic of an engine that was supposedly an LT4.
Now I am wondering if maybe in fact it is an LT4. The engine I was thinking was an LT4 I now see is actually an LT5. So, my question is do the LT4 and LT1 appear to be similar? How can he be sure what engine he really has?
You know what they say, The only dumb question is one not asked! LOL
Thanks for clueing me in!
Rob
Old Mar 20, 2011 | 10:45 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
http://forums.corvetteforum.com/c4-t...t4-vs-lt1.html
This is the noob way to find out
96 LT1: automatics
96 LT4: 6 speeds
LT4 has a red intake
Thats about it.
Old Mar 20, 2011 | 11:00 PM
robs87vette
His is Automatic and no red on the intake so.......
Thanks!!
Old Mar 21, 2011 | 10:55 AM
bac22's Avatar
bac22
Thanks!!
If he paid for an LT4, but got an LT1 I'd be pissed. Not knocking the LT1, both are great engines, but the LT4 (modified version of the LT1), for obvious reasons, tend to be priced a bit higher on the market.
Old Mar 21, 2011 | 11:33 AM
Mrs. glass car's Avatar
Mrs. glass car
You don't have to open the hood on a 96' to find out if it is an LT-1 or an LT-4. Look inside, if it has an automatic it is an LT-1 If it has a 6 speed LT-4 and finally to double check, the tach on an LT-1 goes to 6,000rpm and 8,000 on an LT-4.
Old Mar 21, 2011 | 01:20 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
And the final "proof" to determine a factory LT4 car.
Check the 8th character of the VIN. P=LT1, 5=LT4
Remember, people have swapped the 8k tach and painted their intake red on LT1 cars.
And there is at least one LT4 car out there that has been converted to an automatic.
Old Mar 21, 2011 | 05:56 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
Get a flashlight and pull the oil cap, says LT4 on the head under the oil cap.
Old Mar 21, 2011 | 06:06 PM
SQUIRMIN VERMIN 84's Avatar
SQUIRMIN VERMIN 84
From: Supreme Soviet Peace-Loving Pipple's Kollektive of Seattle Wa
Great info! good trivia! Something to check at shows, etc.
Old Mar 21, 2011 | 06:31 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
.... Look inside, if it has an automatic it is an LT-1 ........
Not always. There's a few "after factory" LT4 autos out there but the VIN will show LT1.
Old Mar 21, 2011 | 06:38 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Well if the VIN says LT1 and the RPO says LT1 is a LT1 and that is a LT1 with LT4 heads and intake. One last thing, the LT4 has more differences than head and intake.
Here this link will answer all OP's questions.
http://www.grandsportregistry.com/lt1vslt4.htm
Old Mar 21, 2011 | 06:51 PM
Blue 92's Avatar
Blue 92
Nope. True LT4. The owner (at that time) was a member here. Had lunch with him once or twice and talked with him many times at shows around the area.
Transplanted LT4 with higher stall converter. Other than that stock.
Old Mar 21, 2011 | 06:52 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Ok so it was a transplant, not OEM. Cool
Old Mar 21, 2011 | 10:01 PM
RollaMo-LT4
And now you know why to check the VIN. It's the only way to tell a true factory LT4.
Same thing goes for the Grand Sport. They have a unique VIN separate from all other '96 Corvettes.
That unique VIN is the main reason a GS can command a higher price than your normal LT4 cars, since there really isn't any other difference between them.
Old Mar 21, 2011 | 10:53 PM
Mrs. glass car
If it makes him happy...but unless he lunched his LT-1 thats a lot of work.
Old Mar 22, 2011 | 09:53 PM
Blue 92's Avatar
Blue 92
A GM engineer was the original owner. I have to assume he got a fairly healthy discount on the LT4.
Old Mar 23, 2011 | 10:12 PM
robs87vette
Didn't want to stir any controversy! I have checked all of the above and confirmed it is an LT1, and yes he was told it was an LT4 at the time of sale, but he doesn't seem to be to concerned about it!!
Thanks to all who responded with all the great info!!
Rob
Old Mar 23, 2011 | 10:20 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Rob
Tell him that I said that because he bought a LT4 he paid more. The ZF6 holds more value in the KBB. I would go back and get me at least $700
To LT1 and LT4 differences
Old Mar 23, 2011 | 10:52 PM
Eakster's Avatar
Eakster
Don't let the seller get away with this. It's criminal at worst, and douchebaggery at the very least. He may have been misled too..
Old Mar 25, 2011 | 10:54 AM
lt4obsesses's Avatar
lt4obsesses
Well, it may have the "LT4 Hotcam Kit" done to it. so perhaps the seller thought himself justified in calling the LT4.
I mean, other than the intake, injectors, rockers, springs, valves, heads, crank, timing gear, compression ratio, etc. it's the same motor, right? I mean they use the same block.
Old Mar 25, 2011 | 11:08 AM
PLRX's Avatar
PLRX
2017 C4 of Year
