MOTOR CLEANING (outside)
Old Mar 21, 2011 | 02:11 PM
ken1950's Avatar
ken1950
Default MOTOR CLEANING (outside)
What is the best way to clean the motor without hurting any of the electrical system ??? This is my fisrt vette 87-C4. I've had H-D's for the last 45yrs.. Last time i worked on a car it had points & condenser. I'VE GOT ALOT TO LEARN !
Old Mar 21, 2011 | 02:20 PM
socalman's Avatar
socalman
St. Jude Donor '10
Rags and elbows until you've morphed into Ringo Starr
'I've got blisters on my fingers!"
Old Mar 21, 2011 | 02:30 PM
96 Vette CE's Avatar
96 Vette CE
Banned Loser
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
Some fine steel wool and simple green will help a lot also.
Old Mar 21, 2011 | 03:52 PM
Chuck Tribolet's Avatar
Chuck Tribolet
'87 doesn't have Optispark, so I'd start with a couple
of cans of Gunk and warm (not hot engine). Let sit 15
minutes with the Gunk on, hose off.
Old Mar 21, 2011 | 04:12 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Not cool at all Dan.
Old Mar 21, 2011 | 04:57 PM
3D87C4's Avatar
3D87C4
Was wondering about engine cleaning too this weekend. How literally can we take the "hose off" suggestion? The last thing I need are shorts...well, in the engine compartment that is.
Presumably one would do this at a mini-wash where the Gunk isn't going to flow into the flower bed or storm drain?
Old Mar 21, 2011 | 05:05 PM
socalman's Avatar
socalman
St. Jude Donor '10
Famous song (Helter Skelter), Mr. Starr yells that. It's actually very cool.
And I just knew somebody would chime in with the Opti and using a hose thing.
It's your car, do as you like, but with the amount of sensors, plug ends that are not water tight etc. I wouldn't run a hose over any engine with EFI. Alternators with intergral VR's, Distributors and your headlight motors don't like water either. Niether does the battery tray.
Don't Vettes have enough grounding issues?
Neil Young said it best.
Rust Never Sleeps
Old Mar 21, 2011 | 05:48 PM
Chuck Tribolet
It all gets wet in the rain anyway with water coming
through the radiator and getting splashed.
The GM connectors are pretty well sealed. Fresh water
is a lousy contducton.
Use whatever source of fresh you like.
Old Mar 21, 2011 | 06:17 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Boy, your an expert on everything, wow. I don't know about others but my engine compartment is pretty dry after driving in the rain.
Old Mar 21, 2011 | 06:41 PM
PLRX's Avatar
PLRX
2017 C4 of Year
This is how I do it since 1997. Only one time I had an issue with my 95, it would not shift to second. few days later it was back to normal.
Old Mar 21, 2011 | 06:46 PM
socalman's Avatar
socalman
St. Jude Donor '10
No fair Pete! You're motor was on a stand at the other side of the garage
Old Mar 21, 2011 | 07:03 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
HHhhhmmmm Is that legal? I had a wash house manager chase me off for contaminating the water. I do that in my yard though with my 90 and 91. Just don't do it too often. Don't want to awaken the gremlins.
Old Mar 21, 2011 | 07:16 PM
3D87C4's Avatar
3D87C4
I used to have a bug that wouldn't run for 3 days after a rain unless I covered everything from the door back with a tarp, so I'm a bit nervous about water on the engine. Fortunately, my engine compartment is more dusty than oily so the rags and elbows technique may work for me.
Old Mar 21, 2011 | 07:17 PM
PLRX's Avatar
PLRX
2017 C4 of Year
They use filters.
Old Mar 21, 2011 | 07:59 PM
mtwoolford's Avatar
mtwoolford
even in california coin op car washes have an "engine clean" option.
back in the day, I'd pressure wash EVERYTHING..and shorts be damned....now I'm more conservative. When cleaning the engine, I soak everything in liquid wrench or pb blast, let set until it has a chance to soften the caked on, baked on grime, then I use brake cleaner and a ton of paper towerls to remove the mess. A little compressed air can be a big help too.
Old Mar 21, 2011 | 08:18 PM
socalman's Avatar
socalman
St. Jude Donor '10
That's because there's a clarifier (tank that seperates oils etc) at the end of the drain.
Old Mar 21, 2011 | 08:34 PM
78pacer's Avatar
78pacer
Spray it down with Gunk de-greaser, then hose it down. You shouldn't have any issues. Just don't purposely try to drown the distributor.
Mike
To MOTOR CLEANING (outside)
Old Mar 21, 2011 | 09:46 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Mike
I wouldn't use a high pressure car wash hose though.
I use a garden hose at home on my LT4. It gets washed 2 or 3 times a year at least.
Over 107K miles, and it looks like new.
Old Mar 22, 2011 | 12:21 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
My choice is "Awesome" from the Dollar Store. Spray it on dry. Use lots, but don't let it get on the cars paint. Then hit it with a power sprayer. The dirt and grease will melt off.
Old Mar 22, 2011 | 05:03 PM
Biker's Avatar
Biker
Been thinking of washing my motor with Gunk and a hose. Does an '86 have an opti?
