Alternator problem?
Old Apr 15, 2002 | 08:37 PM
Tony W's Avatar
Tony W
Default Alternator problem?
I think I'm gonna answer my own question in this post, but I want to ask just to make sure. I started my Mustang (97) up this morning and all was fine for a few seconds and then it sputtered, died, and restarted itself. No warning lights came on, but my electrical system (lights, radio, etc....) faded on and off. It did this about three times and then all was fine. I headed out and stopped at a traffic light and my RPM's dipped down to 500 and sputtered but didn't die. I have never replaced the alternator before, so I'm assuming that's what the culprit is. Am I correct?
Old Apr 15, 2002 | 08:42 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: Alternator problem? (Tony W)
Not the alternator!
carter200's Avatar
carter200
What did your alternator gauge say? If it did not go erratic then don't think it's the alternator :confused:
Old Apr 15, 2002 | 09:16 PM
Tony W's Avatar
Tony W
Default Re: Alternator problem? (carter200)
I don't know if it said anything. I just know that that's the only possible solution I could come up with. :confused:
Old Apr 16, 2002 | 01:14 PM
jfb's Avatar
jfb
The alternator could completely stop providing charging current and your engine should run just fine because the battery will supply power to all the electrical devices for an hour or so depending on the electrical load.
Old Apr 17, 2002 | 09:36 AM
JDF's Avatar
JDF
How can an engine "die" and start again by itself without turning the ignition key to engage the starter? If you were talking about a C4 with an idle problem I would first investigate the I.A.C. valve.
Old Apr 17, 2002 | 02:13 PM
Jim D's Avatar
Jim D
Default Re: Alternator problem? (JDF)
The first thing I would check is the battery connections, put a voltmeter on your battery if you getting 13 or 14 volts your altenator is OK.
To Alternator problem?
