NEED LT1 Alt. bracket pics ect.
Old Mar 30, 2011 | 02:23 PM
derekguzz's Avatar
derekguzz
Default NEED LT1 Alt. bracket pics ect.
Hey guys. Finally buttoning up the hatches on my complete rebuild and need some pics if anyone can go shoot or maybe has some on hand.
Alt./AC Bracket metal support pics
pully pics
pics of injector area
left and right side of valve cover area pics.
I have a general idea of where everything goes I just want to double check and make sure I have everything where its supposed to go before I start her up !!!
Thanks in advance
Derek-
Old Mar 30, 2011 | 07:30 PM
a454corvette's Avatar
a454corvette
Old Mar 30, 2011 | 08:30 PM
derekguzz's Avatar
derekguzz
Thank you for going out of your way a454corvette. You really helped me !!
Old Mar 30, 2011 | 09:32 PM
derekguzz's Avatar
derekguzz
hey in the pic where you are showing the throttle linkage bracket, I wired the alt and the condensor and there is a connector along with those 2. Where does it go into?
Again its part of the alt,condensor plugs, the third one I dont know where it goes?
Old Mar 30, 2011 | 11:05 PM
a454corvette
Hey Derek, no trouble.
On mine (92), after the injector connectors, there is a 2 wire connector to the compressor, the large gauge red wire to the alt, and a 2 wire connector that plugs into the alt at about the 4 o'clock position when viewed from the rear.
Let me know if that doesn't get it for you.
Old Mar 30, 2011 | 11:30 PM
derekguzz's Avatar
derekguzz
you nailed it !!!
Old Mar 30, 2011 | 11:57 PM
derekguzz's Avatar
derekguzz
in the pic where you are showing driver side of valve cover, in between the injectors, upper black thick hose....??
Where does that lead to going right?
Its the upper thick hose NOT the vacuum line.
I lost track of the hose I guess so I dont know where it could lead me to plug it in at the other end.
Old Mar 31, 2011 | 12:00 AM
a454corvette
The one above the "U" shaped PCV goes to the brake booster
Old Mar 31, 2011 | 12:42 AM
derekguzz's Avatar
derekguzz
JUST found it. Thanks again. I had the brake booster line curled back out of the way towards the ECM...Thanks again. I have the driver side done. injectors and all. Now on to the pass side. injector wires,plugs,hoses and ICM/coil and shes ready !
To NEED LT1 Alt. bracket pics ect.
