I am considering buying a 96 lt1 which has headers, flowmaster cat back and a new programmable chip. I live in CT and I am wondering how/if these mods will effect CT emissions testing. Any one out there that lives in CT and has similar mods and went through CT emissions?The car is in nice shape and the price is right, these mods are a bonus and I would be buying it in Long Island NY so I don't know if NY has similar emissions requirements. The car also has 3.73 gears , not that that would effect emissions. Basically it comes with many of the things that I would want to do to it. Thanks
I am also wondering what kind of effect these modifications have on fuel efficiency? Obviously you don't buy a vette for good gas mileage but this will be my daily driver so I am wondering what headers, flowmasters, and gears will do to mpg. The 86 I just sold had stock 2.59 gears, do the 3.73 make it quicker off the line or do you see it more at top end. I am just wondering if this car would not be a good DD, if it's set up more for racing or auto cross. Thanks
Not familier with your air testing procedures down there, but here, the gears would effect pollution. Our systems measure at idle and at 30 mph, with your higher gears, your engine will rev higher at 30 mph and produce more pollutants..
That said. Headers and cat back exhaust should cause you no grief at the sniffer and will help fuel mileage a very tiny bit. As long as the cats are in good shape they don't know what's behind them.. The chip, could hurt. No way to know but I suspect it is a very mild mod which should go unnoticed.
Mileage wise, your rear gears will hurt mileage a bit (engine will rev higher at cruise) and will help the car launch off the line.
I would assume your emission testing is the same as NYC. YOu didn't say if it still has cats (some of the programable chips can fool the computer to think it still has cats if they have been removed). 96 is the first year for OBD2, and they should just plug in to the computer to test. If you don't have a service engine light on, it should pass. You can have it tested at most auto parts stores. The gas mileage will be a lot worse than the 86, figure 10-15 in town, 20 or so highway. LT1's generally average about 25% worse mileage than a L98, gears will definately make it worse. If it's a factor, perhaps you should keep looking....
thanks for the info guys. My 86 got about 16 mpg around town maybe 21 on the highway. I thought the lt1 would be better. I always see guys on here claiming they get 20 plus around town and 27 highway. always seems to be a huge disparity. I'm not going to worry about mpg too much though. Just don't want to buy a car and then not make it through emissions.
I respectfully disagree...the LT series have sequential (timed) fuel injection while the L98's used the earlier batch fire injection..which should give the LT's better gas mileage. Remember it was all about fuel economy and emissions. My 96 with a 6 speed manual and 3.45 rear gears can easily get 28 - 29 mpg at (legal) freeway speeds. But, as they say, "Your mileage may differ".
Unfortunately I have no experience with an automatic and / or 3.73 rear gears; perhaps someone who has run this combo will chime in ?
yeah, I was looking forward to better gas mileage with the lt1. I guess it depends on which one I get. This one has some nice mods so we'll see. I'm just getting impatient which will soon lead to impulsive. Hopefully the right car , my car, will come along soon
After writing the 25%, I thought better of it. 20% would be closer. L98 autos generally get over 30mpg. I've had several mid 80's autos that would get 33mpg @ 75mph. My LT1's (with 2:55's) get about 28, the 3:08s about 26.
From: They say you learn from your mistakes, I must be a genius
2017 Corvette of the Year
2016 C4 of Year Finalist
Creator of the "Original" whining and crying thread
St. Jude Donor '14-'15-'16-'17
I have a '96 LT1 auto with 3:07 gears and get 28 miles to the gallon cruisin' at 70 on the highway all day long.
I'm in CT with similar mods: short tube headers, magnaflow catback, 4.11 gears. I passed the sniffer test without a problem. However, your car being a 96, in CT, will NOT get the sniffer test. It is OBD II and they will link up to the diagnostic port instead. The only thing I can see harming you would be whatever was done in the tune (the aftermarket chip you refer to). If the tune disabled the rear o2s, turned off the air injection pump, etc. it could possibly fail. Other than the diagnostic port test, they will probably do a visual to ensure it has cats and test the gas cap to ensure it does not leak.
If it is running well and has cats you're probably fine.
I bought my car out of state too - they are going to nail you on the taxes.
If that's all you need to do, find someone close to you with the same car and 'borrow' their chip for a day. If it only has headers and exhaust, it doesn't need your chip to run right, it'll run just fine on stock.. Then once you've passed, put yours back in.
94+ is a flash pcm, no chip replacement. If it has a tune it was reflashed. I'd not worry about it. Take it to emissions, if it fails at least you'll know what caused it to fail and go from there. But if it runs right, has cats and no check engine light I'm betting you are just fine.
I would also like to know If I swap out from 307 rearend to 354 or 373 in my 86 with the 700R4 what kind of mileage I be getting and if 373 are to low for a DD.
With the 4 speed auto trans that 96 is not going to get much better gas milage than your older car did and the 373 is going to hurt it as well. My high stall tc really hurts my milage around town where it never locks up and I get around 14 but at a steady 65 I can get 23mpg .... but I am running the stock 3.07 not a 373.
Of course "your milage may differ"
Best of luck to you and let us know what you end up getting .... remember the worst thing you can do .... is fall in love with the first one that you drive.
