Hash mark install.
Old Apr 17, 2002 | 02:37 PM
95Purple's Avatar
95Purple
Default Hash mark install.
Who in Michigan knows how to install the hash marks? Or even a place to go to have it done. I can almost bet that I would mess them up. I have the stick on ones from Ecklers. :crazy: :crazy:
Old Apr 17, 2002 | 02:43 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default Re: Hash mark install. (95Purple)
I did mine a couple of months ago. as long as you take your time, you will get them right.....just be patient
Old Apr 17, 2002 | 02:47 PM
Hurricane_777's Avatar
Hurricane_777
I had mine re-done over the winter at Heritage Collision in Westland. They're a great shop and did an excellent job. The owner is a good friend of the family and even has a vette himself. Ask for Rich if you call :chevy
Scott
Old Apr 17, 2002 | 02:53 PM
Kale's Avatar
Kale
Default Re: Hash mark install. (Hurricane_777)
if I can do it, you can do it. Just mix a LITTLE soap with water in a spray bottle, and make the panel moist
put the hash marks on, squeegee the bubbles and moisture out
Old Apr 17, 2002 | 03:25 PM
GS 163's Avatar
GS 163
Default Re: Hash mark install. (Kale)
Dosent the one from Ecklers come with a template to use?? The first time I had them on my car they came with a template that you just line up with the headlight. I just got some from MAD, but they are junk, no template, and the edges arent cleanly cut. Sending those back and reordring from Ecklers.:)
Old Apr 17, 2002 | 05:56 PM
MY 95's Avatar
MY 95
Default Re: Hash mark install. (JPLT1)
yep...the template helps a lot
To Hash mark install.
