General maintenance
Old Apr 12, 2011 | 07:57 PM
whd1736's Avatar
whd1736
Cruising
Default General maintenance
Well I have recently got a 1985 with a 4+3 transmission, and if I remember correctly had several Z51 options too, passed down to me from my father, and it currently has 131,300 miles on it. The A.I.R crap has been replaced several times(plan on removing it), and I was curious about what kind of maintenance should be done ,or things to look at before I start spending money on mods.
Old Apr 12, 2011 | 08:34 PM
vader86's Avatar
vader86
Well what has been replaced thus far? That will eat up your mod budget considerably at 131K. Just about everything that hasn't failed will fail soon.
Old Apr 12, 2011 | 08:44 PM
whd1736's Avatar
whd1736
Cruising
well there hasnt been much of any work done to the engine...as of right now I know the throttle body needs to be replaced, because it gets stuck once and awhile when the engine is cold. The transmission was rebuilt at 110,000. Of course things like oil changes and tune ups were done at the correct intervals. Other than that I dont know what has been done, and doubt I would be able to find out.
Old Apr 12, 2011 | 09:42 PM
vader86's Avatar
vader86
General maintenance is 30K for transmission/OD unit fluid. 100K for the rear axle fluid which I'm sure hasn't been done. 75K is what I recommend for shocks.
Over 100K, wheel bearings, U-joints, alternator, compressor, etc. are all things that are going to fail if they haven't been replaced already. Then you'll have the usual electrical gremlins and sensor failures, like the MAF.
If that stuff is ok then you can proceed with a few mods, but do drive it for 6 months before you start sinking money into that...things are going to wear out.
Old Apr 12, 2011 | 10:00 PM
whd1736's Avatar
whd1736
Cruising
well I dont plan on going right out and modding it yet, but my main goal right now is to get it a little more reliable, and get used to driving it a little more, then ill worry about modding it. And thank you for the info!
Old Apr 13, 2011 | 06:47 AM
HlhnEast's Avatar
HlhnEast
Thats the smart approach. Good advice for any new C4 owner. Check the hoses and serpentine belt for cracks. If there is any doubt go ahead and replace them. Its a lot easier in your driveway than on the side of the road. The AIR elim is an easy mod but not really cheap. Check Vader's site for more info on this and tons of other info.
Change all fluids especially brake and clutch hydraulic fluid. Flush the cooling system and fill with the proper antifreeze and distilled water appropriate to your climate. Grease anything that has a zerk fitting. Change the oils in the engine, tranny, OD unit (and filter) and rear end. Make sure you use the correct oils and additives where appropriate. After that you are pretty much done with PM.
As Vader has mentioned at 131K things will start to fail. You can go broke trying to guess what is gonna go next and you will go broke trying to figure this out without a crystal ball. Just keep an eye and ear out for anything suspicious and dont let the problem snowball i.e. replace the brake pads before it eats up the disc etc.
Good Luck and welcome to the forum. Post up some pics of your car when you can BECAUSE..........
Old Apr 13, 2011 | 05:49 PM
whd1736's Avatar
whd1736
Cruising
Ok hers some pictures taken last july after I had put the new ZR1 wheels my dad had bought. The car desperately needs a paint job.
Old Apr 13, 2011 | 06:22 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Enjoy your new ride and thanks for sharing the pics.
Old Apr 13, 2011 | 06:23 PM
whd1736's Avatar
whd1736
Cruising
I hope too. My actual ride was that green saab hatchback lol....so this is quite the upgrade for me.
Old Apr 13, 2011 | 07:53 PM
Frizlefrak's Avatar
Frizlefrak
The official Frizlefrak guide to adopting an old car, first 10 things to check:
1. Change all fluids. Include flushing brake fluid, P/S, transmission, and rear end. Repair leaks as needed.
2. Change all cooling hoses, serp belt, and rubber vacuum lines. Flush cooling system. On a C4, remove radiator and clean 20+ years of accumulated crap off the front. You will thank me later.
3. Inspect brake rotors, pads,and brake hoses. Check entire braking system for leaks. Replace anything suspect. Check parking brake and repair / adjust as needed.
4. All new filters. Fuel, oil, air.
5. Address any check engine light issues, and correct.
6. Inspect suspension bushings, ball joints, tie rod ends, and wheel bearings. Replace as needed, get 4 wheel alignment.
7. Cap, rotor, wires, and plugs unless done already.
8. Check date code on tires. Replace if 8 years old or beyond, or any signs of weather checking.
9. Replace wiper blades. Scratched windshields suck.
10. Check operation of all lights and horn, repair as needed.
That should get the car at least minimally roadworthy. There will be more. Much more.
Happy wrenching.
To General maintenance
