I went to refill my tires the other day and noticed the sticker on the inside of the door says "35psi" but the tires say "44psi." Which would you guys go with?
go by what the DOOR STICKER says. Whats written on the tire is what the maximum psi that particular tire is capable of holding safely. You put 44 psi in a vette and your head will hit the top everytime you hit a bump
OMG...don't go by whats on the tire...you run the risk of the tire exploding from overheating. The door sticker isn't based on any specific tire, it's based on weight of the car among other things and is the safe PSI to use in the tire.
I run 35 psi. Remember a tire is a spring....increasing pressure increases the spring rate, and lowering pressure drops it. At 44 PSI, it's gonna ride like a dump truck and not handle any better. The tire says 44 as a max when you are at maximum weight....example a truck pulling a trailer would want max pressure in the rear tires.
my new Michelins say 51 psi max.....thought that was a little high, so I put them at 40-45......might even go to 35, but the way fuel prices are and running premium, I may like the psi at 45
