conv. hatch issue?
Old Apr 15, 2011 | 12:09 PM
bcrich1975's Avatar
bcrich1975
Default conv. hatch issue?
Hi. I am new here and have done a ton of reading on this forum. Very informative to say the least. Not my first Vette, but this one is my first conv. Every Camaro, Trans Am, or Vette I've ever owned has had its fair sahe of squeaks and rattles which I'm used to, but this problem can probably be corrected. The conv. hatch on this car sits flush on the drivers side but not on the pass. side and I know it is the source of the annoying rattle noise when driving. So I took a picture, granted it's hard to really see what I'm talking about but it does not sit all the way down like the other side does with the top up or down. I checked the latch which seems to be fine, put a little white lithium grease on both of them just to do it. Has anyone else had this problem or is it just an inherant design flaw that other conv. Vettes may have? Any help or insight greatly appreciated. Thanks.
Old Apr 15, 2011 | 03:42 PM
turbotim23's Avatar
turbotim23
Are there any bushings worn or missing? I don't know much about convertables but I know my coupe drove me crazy till I replaced the bushing buttons on the rear of black plastic panel under the hatch.
Old Apr 15, 2011 | 04:20 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
It definitely should sit flush. Are you sure that that the right side latch is even fully engaged? If it is, there must be something to adjust. Mine is good, so I've never looked for wear or adjustment points.
Old Apr 15, 2011 | 04:58 PM
jesredvette's Avatar
jesredvette
You might want to consider removing the latch mechanism from the hatch and see if it sits flush; that should tell you where the problem lies.
Old Apr 15, 2011 | 05:48 PM
KEG64's Avatar
KEG64
The latch can be adjusted up or down. There is also a threaded bumper that needs to be adjusted along with the latch to set the correct height of the lid.
To conv. hatch issue?
