C4 Paint Restoration
Old Apr 15, 2011 | 07:35 PM
egm12a10's Avatar
egm12a10
3rd Gear
Default C4 Paint Restoration
Bought an 87 C4 Convert about a month ago and am doing some minor rehabs and restoration. Would like some advice on a paint problem.
This is a white car with mostly original paint in good sound condition however the rear topside from doors back was repainted at some time.
Paint on flat surface below luggage rack developed "cracks" that look like a dried up mud puddle. The paint looked good and thick and otherwise in good shape so I wet sanded it with 1000 grit paper.
95% of the cracks are completely gone but I am hesitant to sand any more
Tried buffing with white polishing compound but that isnt bringing up shine or removing remaining cracks. I have color sanded steel body cars with good success but never a glass body with OEM acrylic.
Should I use a more agressive rubbing compound or is there some other
--possibly safer --way to go???
Old Apr 15, 2011 | 07:38 PM
Kmcoldcars's Avatar
Kmcoldcars
The cracks in the paint probably go all the way to the primer. The only way to get rid of them is to remove all the paint where the cracks are and start over with new paint.
Old Apr 15, 2011 | 08:11 PM
Z51JEFF's Avatar
Z51JEFF
Besides getting rid of the cracks what are you trying to do?You know this pant is 2 stage,color-clear.What your buffing is color,dont know if that will bring up too much shine.
Old Apr 15, 2011 | 09:43 PM
lushdrunk's Avatar
lushdrunk
C4's don't use acrylic paint. They are a two stage urethane paint system, more commonly known as base coat, clear coat (BC/CC).
Cracks in the clear coat are very common on C4's, And they go all the way though to the base.
It sounds to me like you have sanded through the clear coat and are now trying to buff the base coat.
Old Apr 16, 2011 | 09:13 AM
egm12a10's Avatar
egm12a10
3rd Gear
Thanks to all who responded---however, I am pretty sure the old repaint to rear of car is acrylic. The previous owner had the remains of
a quart can of PPG acrylic. Painter did a nasty job of laying down a very thick coat of material over lightly sanded checking and it "sunk" after drying out .
Will try some brown rubbing compound and if that doesn't work will bite
bullet and haul it off for repaint.
To C4 Paint Restoration
