EGR Pipe Heat Shield
Old Apr 15, 2011 | 08:26 PM
Casket86's Avatar
Casket86
Default EGR Pipe Heat Shield
Can anyone tell me if heat shield on the EGR pipe is even necessary? Mine was still original (old, frayed and falling apart) so I cut it off. I was considering just using high temp primer and paint, but I figured I should consult the knowledge base first.
TIA
Casket
Old Apr 15, 2011 | 10:16 PM
Casket86's Avatar
Casket86
Originally Posted by CorvetteMike2004
Replace it. Its as hot as the exhaust pipe. Anything that touches it when hot will cook.
Here you go. Forum vender Corvette Central.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050F
Thanks Mike! Sure glad you are back and feeling better.
Old Apr 16, 2011 | 12:08 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Looks ugly uncovered too.
Dittos on the return of Mike!
Old Apr 16, 2011 | 09:30 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
I know from expierience that puppy gets real warm.
To EGR Pipe Heat Shield
