C4 mgb
Old Apr 25, 2014 | 05:16 PM
  #41
1991Z07's Avatar
1991Z07
That's gonna make some eyes pop when you step on the "go" pedal and leave some serious sportcars in your wake...
Nice build...can't wait to see it finished as well!
Old Apr 25, 2014 | 05:54 PM
  #42
ch@0s's Avatar
ch@0s
Very Impressive
Old Jun 10, 2014 | 09:11 PM
  #43
LT1inaMGB's Avatar
LT1inaMGB
Here are a couple short videos of it driving - go kart mode, I was barely touching the throttle.
Old Jun 10, 2014 | 09:42 PM
  #44
1993C4LT1's Avatar
1993C4LT1
Old Jun 10, 2014 | 10:47 PM
  #45
ch@0s's Avatar
ch@0s
Way too bad azzz!!
Old Jun 11, 2014 | 01:57 AM
  #46
Cliff Harris's Avatar
Cliff Harris
I've seen this before, but still VERY interesting. I read through the 3 linked web pages but couldn't find the 4th one.
I'm amazed that anyone can stick to a project like this and see it through. I've seen many hot rods that were started and never finished. Congrats for the progress thus far.
Old Jun 11, 2014 | 06:56 AM
  #47
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Great fabrication skills
Old Jun 13, 2014 | 03:46 AM
  #48
2HIP4U's Avatar
2HIP4U
Reminds me of the British offerings such as the Sunbeam "Tiger." Or perhaps the AC "Ace" with Shelby's 260 or 289.
This MG is gonna distort space/Time...
Old Jul 29, 2014 | 11:19 AM
  #49
LT1inaMGB's Avatar
LT1inaMGB
If you open any of the links, the link to part 4 is at the top.
Old Jul 29, 2014 | 01:55 PM
  #50
ch@0s's Avatar
ch@0s
Amazing and I love how you took the MG logo and changed it to "GM". Grat job
Old Jul 29, 2014 | 09:58 PM
  #51
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
I just read through all four parts and am thoroughly impressed! Beautiful job!
Old Jul 29, 2014 | 10:43 PM
  #52
LT1inaMGB's Avatar
LT1inaMGB
Thanks guys. I'll post another video after I get it tuned and can open the throttle and make some boost.
Old Jul 30, 2014 | 12:02 AM
  #53
Tommycourt's Avatar
Tommycourt
I posted my reply before but must have forgotten to hit post. This man has tremendous talent. I can tell you from experience (as I have one) you can work with an English wheel for 20 years and never know all the secrets. By cutting the car in half, you completely change the geometry and having to factor in the widened piece is very complex. He is using 16ga steel which is hard to form on an English wheel as it will get you close to what you want and then you have to hammer and dolly. I will form 18ga however 20ga is much easier and then you can seam roll to gain strength and rigidity. Having the correct tools, plus a rotisserie is a body mans dream and if he doesn't have a tool, he has the ability to make it. I think it would be a wonderful experience to talk to him or just be able to work with him and gain some of his knowledge. I am so glad to see someone with skills like this and be able to maintain the perseverance to complete this project. He had my ultimate respect!!!
Tommy
Old Jul 30, 2014 | 01:15 AM
  #54
Klondike's Avatar
Klondike
Wow! That's like one part Doc Brown with the flux capacitor idea and part Carroll Shelby with the fabrication and all genius! I couldn't do that if I was locked in prison with the thing and every tool known to man! Very Very COOL!
Old Jul 30, 2014 | 02:17 AM
  #55
LT1inaMGB's Avatar
LT1inaMGB
Tommy
Thank you very much, not sure I deserve all that praise. If you are ever out in San Diego, send me a PM and I'll give directions how to get here.
Old Jul 30, 2014 | 11:52 AM
  #56
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
This project is one of the best I've seen. I LOVE IT! You're building exactly what you want. So cool.
There was a guy here in SLC that I met at auto x events...he had built a frame/Corvette drivetrain VERY similar you yours, but used a Triumph TR4 body. Fastest, most awesome Triumph I've ever seen!
Love your vision/work/progress.
Old Sep 5, 2014 | 02:40 AM
  #57
LT1inaMGB's Avatar
LT1inaMGB
Got the tune completed today. I was quite surprised - it made 450 rwhp and 543 rwtq, the surprise was that it did it at 4800 rpm and 4000 rpm respectively and well below the peak boost of 8 psi at 6000 rpm. I don't have a video of the pull because I had to sit on the back end to keep the tires from spinning on the rollers. It sounds pretty impressive sitting 2' away from the exhaust tips. The pulley I had on the blower during the previous run was too small and it was making 7 psi at 3800 and over 10 psi at 4500 so we stopped the run. It would have probably been well over 12 psi if we continued. I got a pulley 3 steps larger and this time it made 6 psi at 5500 rpm. The fact that the peak boost was well past the hp peak tells me that the supercharger is too small and is restricting the flow at higher rpm but that is a good thing right now because I still have the stock hypereutectic (cast) pistons in it, the last thing I need right now is more hp at high rpm. I can shift at 5500 rpm and still not drop below the torque peak in the first 5 gears. The car makes over 400 ft lbs of torque from 2700 to 5500 rpm, it pulls like being shot off an aircraft carrier with a catapult. The air/fuel was right at 12:1 under boost and dropped about 1/2 point with the water/methanol injection working. There was never an instance of the knock sensor having to pull timing out due to detonation. I did my happy dance.
If you believe what you read on the internet the flywheel numbers are somewhere between 15% and 20% higher than the rear wheel numbers. If you use the 15% figure that would make the hp 517 and the torque 625 - boggles my mind. I just got on the power rolling in 2nd gear and shifted into 3rd, the clutch didn't slip, the car goes straight and the tires didn't break loose because the power comes on smoothly with the boost but boy does it accelerate!
To C4 mgb
Old Sep 5, 2014 | 08:26 AM
  #58
1993C4LT1's Avatar
1993C4LT1
Nice numbers!
Old Dec 8, 2014 | 02:16 PM
  #59
LT1inaMGB's Avatar
LT1inaMGB
I think I've figured out why the rpm was so low at peak hp. I have a Flowmaster 50 series muffler with a Moroso spin flow muffler in front of it to take out the raspiness from 1800-2400 rpm. Take a look at the attached flow comparisons http://www.exhaustsoundclips.com/cfm.pdf and see why I will be changing to a Dyna Max Ultra Flow. I'll let you know the results
Old Dec 8, 2014 | 03:40 PM
  #60
1993C4LT1's Avatar
1993C4LT1
Looking forward to the results
