trans question
Old Apr 19, 2011 | 11:18 PM
dezl's Avatar
dezl
Default trans question
Im actually in the process of putting c4 suspension under my 55 bel air, Ive also picked up a ls1 but now I need a trans. I found a 6 speed from a c4, I believe its an 93-94. Would this trans work with a newer engine or do I need to pick up a newer trans?
Thanks for the input.
Old Apr 21, 2011 | 11:07 AM
dezl's Avatar
dezl
anyone have any idea?
Old Apr 22, 2011 | 12:38 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It should fit, if you get the bellhousing with it. Most people use the Camaro trans though, cheaper, and it has a trans mount so you don't have to fabricate one.The vette zf6 speed is very expensive to repair. There were a lot of new units for cheap, that GM released a few years back, so when the trans went bad, people just bought the new one, and put the bad one on EBAY or Craigs list.As far as I know, the only way to find out if its good or not is to put it in a car or have a shop take it apart.
Old Apr 22, 2011 | 11:39 AM
dezl's Avatar
dezl
wells thats good to know. The trans is only 500 bucks which I thought was a pretty good deal for a 6 speed.
I keep my eyes out for a camaro trans. Thanks for the info.
To trans question
