Need help identifying an engine part
Old Apr 21, 2011 | 02:54 PM
ODST's Avatar
ODST
Default Need help identifying an engine part
Hello everyone!
I have an 89 that I am having engine surge and random high rpm problems. I started by checking for vacuum leaks and found a line that appeared to be broken off a rubber part at the front of the fuel rail and under the throttle body. Does anyone know what this is and what it does? I'm going to take some needle nose pliers and gently pull out the piece inside and try to fix it. Thank you for any help you can provide.
(Sorry, I'm still trying to figure out how to post pics. I have two pictures I took and put in my album.)
Old Apr 22, 2011 | 09:18 PM
DINO84's Avatar
DINO84
E-MAIL me the pics and I'll check my 89 to see.
judino@charter.net
Old Apr 22, 2011 | 09:27 PM
vetteoz's Avatar
vetteoz
No vac lines to fuel rail
Port under TB supplies vac as shown to EGR solenoid and canister
Old Apr 23, 2011 | 07:27 AM
ODST's Avatar
ODST
Thank you. It's the EGR. Ill just pull the broken part of the tube out and slide the other end in.
To Need help identifying an engine part
