rear end sways
Old Apr 28, 2011 | 10:42 PM
bluehog01's Avatar
bluehog01
7th Gear
Default rear end sways
im new to the corvette world. my 1988 c4 seems to almost steer slightly in the rear of the car when i give it gas and then back when i let off. any suggestions??
Old Apr 29, 2011 | 01:19 AM
Frizlefrak's Avatar
Frizlefrak
Check all of the rear end suspension components, particularly the "batwing" bushings.
Old Apr 29, 2011 | 01:57 AM
Calderone's Avatar
Calderone
Had the same problem,take it to the alignment shop
that will cure most of the problem
http://forums.corvetteforum.com/c4-t...el-or-dec.html
Old Apr 29, 2011 | 09:41 AM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
The tires are pointing away and thats the reason it feels like it is fishtailing.
Old Apr 29, 2011 | 10:58 AM
Frizlefrak's Avatar
Frizlefrak
I agree with the guys above....alignment. Just ensure you don't have any worn suspension components first, or you're wasting your money aligning it. Worn bushings will cause constantly changing alignment. Ensure everything is up to snuff, get a 4 wheel alignment per Pete's chart, and all will be well.
Check your wheel bearings for play as well.
Old Apr 29, 2011 | 08:39 PM
bluehog01's Avatar
bluehog01
7th Gear
thanks guys I'll have it aligned. my first corvette and loving it
To rear end sways
