Removed ABS pump, does it have any value?
Eliminated the ABS & plumbed the system for standard power brakes.
I made a thread on plumbing the lines without ABS, again check my threads started (tech section for this one).
There is a way to create a jumper connection for the brake lines in the well that the ABS pump used to live in check Aardwolf's post(s).
I cut most of the lines out of the chassis. Flared & bent the original front lines & attached them to a tee. Plumbed a new line for the front from the master cylinder to the tee. It all fits nicely between the heat shield & frame.
For the rear I left the original line from the master to the rear. After it makes a 90* bend toward the center of the car I flared it & installed a line splice fitting. A new line was fabricated from the line splice to the manual adjustable brake bias valve. The valve is mounted to a 1/4" aluminum plate that now covers the hole that the ABS mount/bottom cover was bolted to. I plumbed a new line from the bias valve to the junction block for the rear @ the left rear frame kick up.
Do not know if an adjustable bias valve is required however last year I installed the DRM spring in the master cylinder for more rear brake. May need the adjustable valve, may not but I now have the option to dial rear brake in or out.
If I still do not have enough brake to smoke all 4 tires when I want I will keep the stock brake pedal, rip the rest of the system out & go aftermarket.
Rotors are true & indexed to the hubs, SS hoses, calipers are rebuilt, booster #3 just installed along with new softer pads. It has the J55 brake option, it should stop.
