Delayed AC Top Vent Output
Old Apr 19, 2002 | 01:26 PM
1Patriot's Avatar
1Patriot
Default Delayed AC Top Vent Output
This is a 96, LT1, Coupe w/46kmiles. No previous problems.
Since the last 5 days the AC system waits from 2-3 minutes before air is present at at Instrument Panel Vents. This happens on both manual and on automatic and regardless of the output selection. The fan speed has been tried at each of the speed on manual and automatic.
Once the air is moving from the IP vents is comntinues to fuction OK untill you shut off the engine and restart; again the wait for the air. No messages on the display.
Also missing is the sound of the damper doors changing position behind the dash.
Any one solved this type problem or have any ideas about where to start to get a solution?????
Old Apr 19, 2002 | 02:39 PM
98nassau's Avatar
98nassau
Default Re: Delayed AC Top Vent Output (1Patriot)
My 96 is doing the exact same thing. I work for a Jaguar-Chevy dealer but they can't look at it until 4-24. Post your message on the tech board and let's see if anyone can help us!!!
Old Apr 20, 2002 | 01:28 AM
1Patriot's Avatar
1Patriot
Default Re: Delayed AC Top Vent Output (INDEBT4MYVETTE)
ttt
Old Apr 20, 2002 | 03:47 AM
bigdan's Avatar
bigdan
this has been brought up before, try a search and/or tech tips.
Old Apr 20, 2002 | 10:15 AM
RIC96's Avatar
RIC96
I had that once, dealer said that the orange vacuum hose was kinked. :confused:
Old Apr 20, 2002 | 01:07 PM
1Patriot's Avatar
1Patriot
Default Re: Delayed AC Top Vent Output (bigdan)
Have run a search for recent and archived articles; no luck so far.
Any other ideas out there, Georgia is getting hot.
Old Apr 20, 2002 | 02:02 PM
silver & red CE's Avatar
silver & red CE
There is always some delay, it's programmed that way in case there's a mildew odor in the HVAC. As long as it still changes over after a few minutes, it's fine. Once it stops changing over after a few minutes, there's a vaccum T on the intake that tends to crack.
Eric
Old Apr 20, 2002 | 02:22 PM
1Patriot's Avatar
1Patriot
Default Re: Delayed AC Top Vent Output (silver & red CE)
Thanks, I'm just not use to the waiting 2-3 minutes; and the sound of the dampers closing is also missing, no more clunck.
To Delayed AC Top Vent Output
