engine temp on1996 LT4 engine
Old May 2, 2011 | 02:42 PM
fishfirst's Avatar
fishfirst
Default engine temp on1996 LT4 engine
What is the runnin temp on a 1996 LT4 engine. Thanks for the info.
Old May 2, 2011 | 02:49 PM
aminnich's Avatar
aminnich
Fans come on at 228* and 237*F. So stop and go traffic expect 230*, generally about 210* on the highway. 260* is the shutdown point. Also, the digital gauge is a little more accurate than the analog gauge.
Old May 2, 2011 | 02:50 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
At any speed above 35mph, you should run in the 195°F - 200°F range (Digital gauge)
Sitting at stopped for any length of time (traffic light, heavy traffic), the temps will hover in the 217° - 235°F range (Digital gauge).
Note: Above assumes all factory settings and equipment.
Old May 2, 2011 | 02:59 PM
purvissp's Avatar
purvissp
Be sure to check the temp on your digital gauge. My analog gauge is about 30-40 degrees higher than my digital when it gets much over 200 degrees.
Old May 2, 2011 | 05:42 PM
Klondike's Avatar
Klondike
Mine settles in at 209* and pretty much stays there as long as I'm moving. Traffic gets it into the 220's. When I have the A/C on which runs the fans, it actually runs a few degrees cooler in traffic 200*-205*.
Old May 2, 2011 | 06:35 PM
RollaMo-LT4
Yep, the Corvette is one of the few cars that will actually run cooler with the A/C on,
because it forces the cooling fans to run at a lower engine temperature than they normally would.
To engine temp on1996 LT4 engine
