compressor problem
Old May 4, 2011 | 12:21 PM
oldtimer's Avatar
oldtimer
Default compressor problem
I own a 92 coupe. I had the freon changed to R134a . The compressor will not engage. A preliminary check shows no signal from a computer to engage the compressor. My question is which computer engages the air cond. compressor. Is this compter available online from a parts distributor. If possible I'd rather fix the problem myself than go to a Chevy ($$) dealer. Thanks for any info that can be shared on this problem. Gary
Old May 4, 2011 | 12:55 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
It's the ECM (engine computer). However, I'm about 99% sure thay isn't your problem. Have you disconnected your battery for about 5 minutes. If the computer doesn't sense enough pressure in the line, in so many trys, it won't signal the compressor. Sometimes the system gets "stuck" after not sensing for a length of time, or so many cycles.
Old May 4, 2011 | 01:42 PM
oldtimer's Avatar
oldtimer
Thanks I'll diconnect the battery and try that fix . Gary
Old May 4, 2011 | 02:06 PM
oldtimer's Avatar
oldtimer
Itv worked!!! thankyou. It blew CLOD AIR !! Thanks again
Old May 4, 2011 | 02:16 PM
oldtimer's Avatar
oldtimer
In was so relieved I forgot how to spell. Thanks again zr1fred and all who gave suggestions. This is a one great site!! I'm retired so any time I can stay out of any repair facility it's great. Gary
To compressor problem
