Ground Problems 1989 c4
Old May 9, 2011 | 08:54 PM
kkdann's Avatar
kkdann
Cruising
Default Ground Problems 1989 c4
Anyone have a picture of the chassis ground points on a 1989 c4
Thank You Dan
kkdan13@yahoo.com
Old May 11, 2011 | 01:30 PM
polo91cnvt's Avatar
polo91cnvt
Dan,
Get a copy of the Service Manual with the electical section (if it is separate). The electrical pages possibily have a tocic called the grounding distribution, showing the grounding circuits and the other topics (head lights, tail ligths, starter and charging) will provided you with the location of the grounding circuit. Typically there are about a dozen (don't quote me on this as I did not count them) or more locations depending on the components supported. The main ground circuit is on the right side rear of the motor usually connected to bell housing and the chasis. At least that's where they are on my '91 and it will a least be close on yours and I have not a clue where the orginal location is as the '91 was put together after motor replacement by a profiessional(?).
Good luck Polo
Old Jun 12, 2011 | 12:02 PM
helphos's Avatar
helphos
Default Ground distribution
Like KKdan i'm suspicious that I have some ground problems, but I HAVE the 93 Service Manual.
It shows simplified electrical diagrams, but no illustration of where 'G101' or 'G106' (or more to the point, where S235 and S213) might actually be located so that I might inspect and clean the things. There are descriptions farther back in the manual, but not always helpful. A picture would be worth a thouusand words!
Thanks!
Paul
Old Jun 12, 2011 | 12:55 PM
blackbear bob's Avatar
blackbear bob
Try these for now. Bob
Old Jun 12, 2011 | 08:29 PM
helphos's Avatar
helphos
Default Ground wire locations on c4
Thanks, Blackbear Bob!
This gives me something I can sink my teeth into. Next Saturday I'll be looking at those ground wires and cleaning or replacing the connectors.
Paul
Old Jun 12, 2011 | 11:07 PM
kkdann's Avatar
kkdann
Cruising
Thank you very much for the help.
I think this will do it.
Old Jun 23, 2011 | 01:48 PM
joe paco's Avatar
joe paco
Paul
goes for me, too Bob! had located some, must have missed others. 91.
saludos, joe
Old Jun 23, 2011 | 06:44 PM
blackbear bob
Your welcome. I have full acess to Alldata and don't mind linking anything for you. Any more just ask. Bob
Old Jun 23, 2011 | 08:47 PM
h.d.fire's Avatar
h.d.fire
saludos, joe
DITTO!
I believe some of the issues I was having were ground related.
Always pays to keep them clean and tight!
To Ground Problems 1989 c4
