code readers
Old May 12, 2011 | 07:06 AM
chatham's Avatar
chatham
Default code readers
i have no experience with code readers. which type or which code reader should i purchase? this would not only be used with the vette but many other cars as well. where should i buy it, autozone, harbor freight, sears, etc?
i would appreciate all advice.
Old May 12, 2011 | 09:03 AM
TWISTERUP's Avatar
TWISTERUP
AutoXray sells good scanners with a variety of cables for OBD1 (your vette) and OBD2 '96 and up. You'll be much better off getting a scanner capable of showing freeze frame and live data. The cheaper "code readers" you'll see pull codes only--no data. True scanners aren't that pricey depending on the features I have a older AutoXray for home use (works great) and a high dollar SnapOn w/scope I use on the job. For "diyers" a brand such as AutoXray work great. Check online there are usually some decent deals there.
