Lift ???
Old Apr 20, 2002 | 05:25 PM
Idreamofvettes's Avatar
Idreamofvettes
Default Lift ???
How high of a ceiling do you need for a lift? Mine is 9' 8".
Old Apr 20, 2002 | 05:43 PM
LPDesRoche's Avatar
LPDesRoche
Default Re: Lift ??? (Idreamofvettes)
Not gonna work...unless you are only 3ft tall and having the bottom of your car at 4ft is going to work for you...and even at that you could not lift your hood while the car was on the lift. :D :D
Old Apr 20, 2002 | 07:10 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
You want 14+ feet. If you go through the trouble to install a lift, you want to be able to get anything up on it. Higher than 14 is better.
Old Apr 20, 2002 | 07:39 PM
2 Ag R8Cs's Avatar
2 Ag R8Cs
From: Retired Suffolk County Police Dept NY South Carolina
Default Re: Lift ??? (PeteL)
Wrong My celing is 10'9" I can stand under my (bend over a tiny bit)vette, but I have to bend or use a seat on wheels to get under my (Yes I do only have 4' when I get under the Jeep but sometime you have to get by with what you got)Jeep wrangler. I am 6" tall. The garage came with a 10'9" ceiling when I bought it If I was going to build a garage from scratch 14-15', but you can get by with less.
[Modified by SilverC4andC5bothR8C, 6:41 PM 4/20/2002]
Old Apr 21, 2002 | 07:56 AM
Lionsden's Avatar
Lionsden
Ceiling 9'8", corvette approx. 45", couple inches corvette to ceiling clearance, ramp thickness 5" = 64" bottom of ramp to floor and about 74" bottom of car to floor.
My garage ceiling is a little higher. If I only had a 9' 8" ceiling I would have a lift. So much better than a floor jack.
To Lift ???
