Window Problem (w\ video)
Old May 14, 2011 | 06:22 PM
Gryz88's Avatar
Gryz88
Default Window Problem (w\ video)
I was driving home, heard a POP while rolling up my drivers side window, and now it refuses to open or close. I looked at the operation of the regulator and the window's attached fine and can be manually pulled up or down. The motor itself turns the armature, I can't figure out what is wrong, there's a video of the operation below.
http://youtu.be/VFi4byzYGVY
Old May 14, 2011 | 07:42 PM
Keystring's Avatar
Keystring
Looks like the gear broke.
Old May 14, 2011 | 09:22 PM
Gryz88's Avatar
Gryz88
Can you clarify the gear exactly...do you mean the gear whose teeth is in the motor? (and is shown turning in the video)
Is that supposed to be connected to the regulator? At the moment...it isn't.
Old May 14, 2011 | 09:58 PM
TWISTERUP's Avatar
TWISTERUP
The large half moon gear which the motor is moving--should be attached to the arm I'm seeing in the video--the arm appears to have broke loose/free of the gear. There should be two arms which work to raise and lower the glass sort of like scissors. You'll need to replace the regulator assembly. The large gear is spring loaded so use caution (keep fingers clear) when you remove the motor from the regulator.
Old May 15, 2011 | 02:23 AM
Gryz88's Avatar
Gryz88
That is exactly what I feared because the regulator is like $280. Do I have to worry about removing the motor because the regulators all seem to come with the motor.
Old May 15, 2011 | 06:12 AM
TWISTERUP's Avatar
TWISTERUP
Since motor and regulator come as a unit--no worries
Old May 15, 2011 | 09:10 AM
icemaidenz's Avatar
icemaidenz
what year is it ill see if i csn find oen without the motor this cheaper im awesome at findin deals
Old May 15, 2011 | 11:16 AM
Richard Church's Avatar
Richard Church
Pull the regulator out , you probably have a big rivit shered.Maybe replace the rivit or have it welded. Those regulators are finger eaters. be careful.
Old May 15, 2011 | 12:00 PM
Gryz88's Avatar
Gryz88
It's an 88, so far this is the best I could find. If you can beat that let me know.
Old May 17, 2011 | 12:45 PM
95fxdwg's Avatar
95fxdwg
Default window regulator
this can be fixed with a nut and bolt or new rivet , take a better look at it and you will see the rivet has worn out and you don't need a new regulator , you should be able to fix this for under $1.00--- look harder you will see the missing pivot rivet
To Window Problem (w\ video)
