ok Dumb question
Old May 17, 2011 | 12:27 PM
Qiken's Avatar
Qiken
Default ok Dumb question
On the distributor lock down clamp,which is the correct way its fitted,
Old May 17, 2011 | 05:15 PM
bsmutz's Avatar
bsmutz
It's a clamp. The two fingers go on the metal ring at the bottom of the distributor where it goes into the intake manifold. Position the clamp with the fingers on either side of the shaft and logic should tell you which side should go up to put the most downward pressure on the distributor when you tighten the bolt.
