C4 dragging
Old May 19, 2011 | 09:28 AM
RJP3526's Avatar
RJP3526
Default C4 dragging
Love the C4, one question though - when I go over speed bumps, many times I scrape something on the bottom of the car. I have not looked to see what scrapes as of yet. Does anyone know, on C4's (mine is an '86 roadster), what exactly is the lowest thing hanging down under there that will scrape first - just trying to determine if its something to worry about or not. Thinking maybe it could be the exhaust system/resonator hanging down at lowest point. Not sure though. Thanks.
Old May 19, 2011 | 09:32 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Most C4's will do that if the speed bump is very high.
You don't have a lot of ground clearance to begin with.
And your roadster has a cross brace under the car, that probably hangs down just a tad more.
Best option is to go really slow, and hit move at a slight angle.
I'll still hear a slight scrape sometimes though.
Old May 19, 2011 | 09:49 AM
Goldcylon's Avatar
Goldcylon
However looking under my car I found an after market exhaust hanger bolt was my culprit over the long speed humps. Get the car up in the air and look underneath. The scrape points will become obvious.
Old May 19, 2011 | 08:53 PM
Azriel's Avatar
Azriel
I had the U-clamps from the exhaust improperly installed for a while, and they were scraping.
Old May 19, 2011 | 09:43 PM
Tommy T-Bone's Avatar
Tommy T-Bone
St. Jude Donor '06-'07-'10-'11-'12-'13-'14
My X brace is banged up from speed bumps on my 91. I developed a rattle when I shift in reverse. Just a little tap,tap, tap that wasn't there until I hit a couple of speedbumps. I don't even like to drive my cars to visit my mother because of the sharp curb angles going into her complex and the monstorous speedbumps they put in the throughways. It's a freakin bang fest (with low cars) where she lives.
Old May 20, 2011 | 08:48 AM
Calderone's Avatar
Calderone
It's amazing that with our cars, we have to get creative and create total new routes to get to a place to avoid all the bumps ! lol
It's happening worldwide,believe me !
Old May 20, 2011 | 10:22 AM
jmgtp's Avatar
jmgtp
I go over a dozen speed bumps each time I leave/arrive (condo complex).
Two things help, one I go as slow as possible over them, and two I hit them at an angle rather than straight on.
But, all too often I bottom out. And worse of all, it is the ZF6 that takes the hit! When I last changed the engine oil I also took the time to pull a few small chunks of speed bump asphault off the lowest point at the front of the trans.
Old May 20, 2011 | 02:52 PM
turbotim23's Avatar
turbotim23
Unless you drive a convert. and have the x brace the most likely thing to hit is the skid frame between engine cross member and radiator support. I'm mounting wheels in this area as my car is lowered and will be even lower than stock. If you don't want to go to that much trouble It would be pretty easy to mount thin plastic pieces where it hits. That would protect the two areas it drags on. Mine was almost worn to the point of having holes in metal and that was from when it was at stock ride height.
Old May 20, 2011 | 02:58 PM
pmihaltian's Avatar
pmihaltian
Slingshot
X brace is the first to hit followed by the rear Y-pipe. If you hit with any degree of force, you can dent or worse yet, flatten the Y-pipe. Be careful,
To C4 dragging
