Poly Bushing help
Old May 20, 2011 | 08:52 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Default Poly Bushing help
Bought the 84-96 kit from Energy Suspension but received no instructions. Contacted them and they referred my to Prothane. They have not responded.
I had the understanding that instructions were included per another forum member.
Anyone have them and can email to me?
Old May 20, 2011 | 12:58 PM
C41987's Avatar
C41987
On their website, http://www.energysuspensionparts.com...sp?prod=3.3142 , at the bottom there is instructions in PDF file, http://www.energysuspensionparts.com...sion/17052.pdf & http://www.energysuspensionparts.com...sion/17019.pdf . These were the front.
Old May 20, 2011 | 01:25 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
The instructions are simple. Remove the rubber, insert the poly.
Seriously, that's about it. When installing the kit in my 86 the entire front suspension was removed then cleaned. The kit was opened and it became obvious where the poly bushings/sleeves belonged.
Of great importance is to understand the bushings replace the rubber and do not require lubing where they press in. The lube should be used where the bushing pivots or contacts flanges. You should be able to identify where lube is required by observation.
Good Luck
Old May 20, 2011 | 02:56 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
whatever you do, do not press the wishbone without supporting both ends.
Old May 20, 2011 | 06:35 PM
Cruisinfanatic
can ball joints be reinstalled. Nothing wrong with mine
To Poly Bushing help
