Hi beam headlight problem
Old May 21, 2011 | 05:23 PM
tjvette90's Avatar
tjvette90
Default Hi beam headlight problem
All,
A quick, and I hope easy, question:
The high beam on my 90 vert was out. No problem, just pop old one out and pop new one in.........Hi beam still out!!
What's wrong here?
Thanks in advance.
Old May 21, 2011 | 06:10 PM
jeffp1167's Avatar
jeffp1167
when the tilt knuckle goes bad you sometimes can't pull the dimmer switch back enough to make the dimmer switch work.
Old May 21, 2011 | 06:36 PM
tjvette90's Avatar
tjvette90
Default hi beam headlight problem
forgot to mention that it's the driver's side that wont work (entire light is "out" when hi beam switch engaged). The passenger side works fine.
Old May 22, 2011 | 01:32 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Here's the schematic.
If you look right below the driver side headlight bucket there is a 3 wire connector called C2 in the schematic.
1) Black wire is ground
2) Tan wire is 12 volts for the low beam
3) Light Green wire is 12 volts for high beam
Disconnect the plug.
With a meter or test light at the connector end that comes from the headlight switch (turn the high beams on). You should measure 12 volts from the Black wire to the Light Green wire.
If you do, something is wrong with the wiring from that point to the headlight bulb.
If no 12 volts there is a wiring problem from that point back
to the 42 pin bulkhead connector (C100 in the schematic) that is
located behind the battery and goes thru the firewall.
Old May 22, 2011 | 11:16 PM
tjvette90's Avatar
tjvette90
"Hooked",
Thanks for the info!! I'll check this out when I get home from work tomorrow.
Old May 23, 2011 | 09:46 PM
tjvette90's Avatar
tjvette90
ok, reads 12 volts so must have a short in the green wire somewhere between the connector and the bulb. Will take a closer look at the assembly later this week. Seems like a breach at either the connector itself or at the bulb.
Thanks for your help with this!!
Old May 24, 2011 | 08:18 AM
Hooked on Vettes
Must be a break in the Light Green wire.
Only thing I can recommend is to remove the whole headlight bucket assembly so
you can work on it on the bench. Otherwise you may end up with a back ache.
Old May 25, 2011 | 12:20 AM
tjvette90's Avatar
tjvette90
Yes, that's the plan. Maybe I'll take a look at the bearings while i'm at it. Replaced them about 6 years ago so might be due.
Thanks, again, for your help with this.
Old Feb 2, 2012 | 09:08 PM
Bobby Joe's Avatar
Bobby Joe
Jeff,
I don't want to jack this thread. I just posted a question about this about 30 minutes ago in General Discussion. I think your answer more applies to what I'm trying to figure out. Do you have more details? Is it an easy fix? Parts available? Jerry-rig it?
Curious....
To Hi beam headlight problem
