how do i fix my console button spring?
Old Apr 21, 2002 | 09:12 PM
dmalhi1's Avatar
dmalhi1
Default how do i fix my console button spring?
the spring went missing from the lil latch assembly of the console door and so the button doesn't pull forward and keep the lid shut so anyone can freely lift the thing open without using the button.
anyway to replace the spring without spending a truckload of money????
Old Apr 21, 2002 | 10:19 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: how do i fix my console button spring? (dmalhi1)
check Ecklers or Mid Am, they have the spring in there for a couple bucks.
Old Apr 21, 2002 | 10:27 PM
R23HTC's Avatar
R23HTC
Default Re: how do i fix my console button spring? (Mr Mojo)
I got the spring and button kit for like $10 I think. You then just have to disassmble the door, repair, and put it back together.
Old Apr 21, 2002 | 10:40 PM
SlowJoe's Avatar
SlowJoe
Or if you are really cheap, you can look at the one in the catalog, break out a pair of tin snips, and give it a shot. Worked for me :D
Old Apr 22, 2002 | 05:18 AM
dmalhi1's Avatar
dmalhi1
Default Re: how do i fix my console button spring? (SlowJoe)
:lol:
not cheap but just don't like waiting for little parts like that in the mail.
Old Apr 22, 2002 | 06:51 AM
Dan Parker '96's Avatar
Dan Parker '96
Mine broke and I used some 5/16ths foam weather stripping. The height was perfect and a small doubled over section provides perfect tension. The plus is it'll never break again and eliminated the slop.
Old Apr 22, 2002 | 07:02 AM
joecaver's Avatar
joecaver
From: 63.8% of all statistics are made up on the spot.
St. Jude Donor '08-'10
I bought a small coil spring at the Home Depot and cut it to length. It was about 1/2 inch dia. x 1.5 long and cost about 50 cents. No problems since.
Old Apr 23, 2002 | 09:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: how do i fix my console button spring? (R94 LT 1)
I concur on the MAD repair kit for around $10, but I didn't have to remove the console lid door in order to repair mine. You should be able to service simply by opening the lid and working on it from the underside without any drama.
To how do i fix my console button spring?
