Smog
Old May 24, 2011 | 09:52 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
Default Smog
Crap! failed smog today. Everything was just a hair too high, time for some new cats I guess.
Old May 24, 2011 | 10:25 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
How often do you drive the Vette?
Were the cats hot?
Old May 24, 2011 | 11:14 PM
kimmer's Avatar
kimmer
I drive quite a bit and the cats were hot but I know one was blown out, the marble rattle and honeycomb out of the exhaust.
Old May 25, 2011 | 12:16 AM
mike100's Avatar
mike100
Is there an affordable LT1 style of catalyst in this state?
Old May 25, 2011 | 12:55 AM
PLRX's Avatar
PLRX
2017 C4 of Year
Come on Kim, if you knew it was already busted then you knew you were going to fail. Is like going to the SMOG shop with the engine light on.
Why did you gamble?
Old May 25, 2011 | 12:57 AM
PLRX's Avatar
PLRX
2017 C4 of Year
There is nothing affordable as long it has the name "Corvette" attached to it. It would be cheaper to build one using a bullet style cat.
http://www.summitracing.com/search/M...s/?Ns=Rank|Asc
Old May 25, 2011 | 07:42 AM
kimmer's Avatar
kimmer
Pete, friend gave me a cat to use that was suppose to be good, it was not. and the tailpipe #'s were typical of at least 1 bad cat if not both. Everything was a bit high not too bad.
Old May 25, 2011 | 07:44 AM
kimmer's Avatar
kimmer
Magnaflo sells CARB direct fits for 325 a piece or universal for about a c note.
Old May 25, 2011 | 09:59 AM
PLRX's Avatar
PLRX
2017 C4 of Year
would be nice if you can find a cat from a low mileage junked LT engine. All 92-96 will fit yours.
Old May 25, 2011 | 11:47 AM
kimmer's Avatar
kimmer
It's only money, got to spend it on something.
Old May 25, 2011 | 12:45 PM
cv67's Avatar
cv67
St. Jude Donor '05
Magnaflow/Carsound cats are nice and affordable.
hotexhaust.com
Dealt with Eric there not sure if they are still around.
Gave a good deal and service though.
Old May 25, 2011 | 02:53 PM
kimmer's Avatar
kimmer
That's what I'm going with. Plus I will be changing the 02 sensors.
Old May 26, 2011 | 10:00 PM
kimmer's Avatar
kimmer
Just tested my egr, diaphram moved but won't come back. One piece of the puzzle is revealed, Nox.
To Smog
