need help
Old May 26, 2011 | 10:19 PM
joebugknee's Avatar
joebugknee
Default need help
Hi everyone im here to pick your brains again. My 87 vette cuts out when i make hard turns and accelerate at the same time. If i turn on an on ramp and step on it its just like i shut the key off.If i let off on the fuel it picks it right back up.Any ideas?last couple of times it backfired when it caught again if that helps any.Its one thing after another with this car im glad i have a 79 to fall back on cuss it never lets me down.Plez help me out guys
Old May 26, 2011 | 11:02 PM
MissileDoc's Avatar
MissileDoc
How much gas is in the tank when this occurs? If it is at 1/4 or below, it could be fuel starvation at the fuel pickup in the gas tank. If this is the case, try it with a full gas tank and see if the problem goes away.
Old May 27, 2011 | 09:20 PM
joebugknee's Avatar
joebugknee
There is almost a half of a tank.Is there not a baffle around the pickup to prevent starving when cornering?
Old May 28, 2011 | 10:28 AM
pmihaltian's Avatar
pmihaltian
Slingshot
If you still have the original fuel pump on your car, it may be time to replace it along with the filter sock on the end of the pump pickup.
I used to have this problem when my fuel tank was at 1/4 full or below. After I replaced the fuel pump, pickup sock and fuel filter these fuel starvation problems went away.
FWIW.
Old May 28, 2011 | 10:43 AM
WW7's Avatar
WW7
I have had the same thing happen with a half tank of gas...One way to check it out "if you can afford it" is to fill the tank and see if it still does it.....WW
Old May 28, 2011 | 07:08 PM
MissileDoc's Avatar
MissileDoc
To need help
