Gas Cap Question
Old May 29, 2011 | 01:57 AM
marcus410's Avatar
marcus410
Default Gas Cap Question
I stopped to get gas tonight and when I unscrewed the cap it made a huge gasping for air sound.I had used about 3/4 of a tank before stopping for this fill.Is this normal?........None of my other vehicles have ever done this,thanks
Old May 29, 2011 | 08:46 AM
VetteMed's Avatar
VetteMed
Normal, especially when not much fuel left in the tank. However, it is also possible that you could have a problem with the charcoal canister and evaporative emissions system if it seems like an excessive amount of pressure in the tank.
Old May 29, 2011 | 09:25 AM
Motsiv2's Avatar
Motsiv2
Pretty common. Mine and a lot of friends do it too.
Old May 29, 2011 | 09:34 AM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Our Honda does it ALOT.
Old May 29, 2011 | 10:48 AM
mcnulty95's Avatar
mcnulty95
Mine always does that, nothing to be worried about.
Old May 29, 2011 | 11:07 AM
jon0108's Avatar
jon0108
Mine used to do that. I ended up changing all the emission hoses going to the charcoal canister thats in front of the car and changing the canister control valve also. No more hissing
Old May 29, 2011 | 11:12 AM
mike100's Avatar
mike100
Just so long as the air is going in and not whooshing out. The excess pressure gets vented to the purge system which gets burned off in the engine- it's a one-way pressure valve. Both of my C4's I had did this. Apparently a slightly lower tank pressure develops on these models.
Old May 29, 2011 | 12:57 PM
3D87C4's Avatar
3D87C4
Originally Posted by Motsiv2
... a lot of friends do it too.
I think we're all making "a huge gasping for air sound" at the gas station these days.
Old May 29, 2011 | 01:50 PM
Azriel's Avatar
Azriel
So, if it wooshes out, what needs replaced? I can already hear my wallet crying.
Old May 29, 2011 | 04:00 PM
mike100's Avatar
mike100
well, maybe not, the car doesn't purge the tank all the time..it can build pressure just sitting there...anyhow, they all do this- Mine passes the evap pressure test the smog man gives it- I wouldn't worry about it.
If you ever pull the fuel line off and leave it hanging, temperature change will put a small pressure in your tank and push gasoline out the end of the line. I had to store my car with the cap off when I had the injection all taken apart.
Old May 29, 2011 | 06:05 PM
marcus410's Avatar
marcus410
Thanks for the info guys
Old May 29, 2011 | 06:51 PM
Lathroum's Avatar
Lathroum
Mine actually "wooshes" out if I run it down low...
I was under the impression that this is normal because the Corvette uses a pressurized closed fuel system... it is not vented...
am I right?
Old May 29, 2011 | 07:21 PM
jon0108's Avatar
jon0108
actually it is vented. Thats what the charcoal canister is for. The purge control valve vents it to outside air. If you look under the canister theres a vacuum line that just vents to the outside
Old May 29, 2011 | 08:38 PM
wnafly's Avatar
wnafly
It's suppossed to do that, thats why the owners manual says to open slowly. I open mine a little until it stops, then remove it. Hope this helps.
Old May 29, 2011 | 09:29 PM
mike100's Avatar
mike100
The EPA may disagree with you.
Perhaps your car has been screwed with by bubba sometime in the past- it's supposed to be a closed system and when the engine is warm, the purge solenoid vents it to the intake manifold or throttle body to burn off the fumes thru the cats and out the pipe. Unburned gas fumes are 10 times worse than regular exhaust fumes...
If you ever have the chance to put an emissions analyzer next to an open can of gasoline, you'll see it peg off the charts for HC's- so much so that it is hard on the machine and could damage it.
you should fix yours, it doesn't rob HP.
Old May 30, 2011 | 10:32 AM
jon0108's Avatar
jon0108
Just checked. Even still had the print out the chevy dealer gave me about the routing of the lines. Its been a while. But youre right. It does vent to the intake. The vacuum line I was referring to that I initially said vented to the outside is actually the bottom of the charcoal canister fresh air intake
To Gas Cap Question
