What the HEY! Drove to work early this AM, using the headlights on my
'94. On the way home in the PM, I noticed that the drivers-side headlamp
was stuck in the "open" position. After repeatedly turning lights on & off,
to no avail, I tried to force it shut, but it wouldn't budge. What's going on?
Please explain/HELP!
raise the hood, use the black **** near the headlight to lower it down. If you hit the switch, and hear the motor but nothing happens, it's probably the bushings in the motor. If there's no sound at all, it's either a bad connection, short in a wire, or the motor is toast.
